Samsung DLP HLN617W, black wavy lines in the picture, but only when watching Cable TV. DVD movies are great. Started a month ago (owned set for 4 years), would show up at power up and go away after 20min or so. Now its all the time. Have 4 other TV's (not DLP) and none have this problem. So far in the TV's life, its had a color wheel replaced 2X and the light replaced 2X. Last repair was 7 mos ago.
  • 796 Answers
If video is good on DVI input, the problem is only the digital board. Just watch it on DVI or use a high end stereo reveiver to switch digital inputs to DVI. The DMD board is not bad if any input is good
Posted on Mar 23, 2008
  • isaac johny
    isaac johny Mar 23, 2008
    also if you have some electronic appliances like air-conditioners and something like that can also cause such lines.....
    just disconnect all the cables n try to see whether still the problem exists/...
    Guru:
  • 1,894 Answers
I thnk the problem is with the power circuit
  • dewan nafees ahmed Mar 23, 2008
SOURCE:
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Display problem with my Samsung HLP5085W DLP TV
What you are describing sounds like a tuner issue. Samsung had a run of bad tuners, and was recalled. If your watching a chennel and the image tears, this is the sign of the bad tuner. It is possible that the wobulation circuit is unstable. First units we bothered by subwoofers thumping the TV. Not much help other than that, good luck
Jul 07, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
61" Samsung DLP w/ no sound
my speakers died some time ago, it wasn't worth fixing, went to a component 5.1 speaker setup. good luck.
Aug 15, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Picture is of poor quality (wavy)
This may indicate a problem with the RF tuner. When you are using the DVD player is the output of the DVD using the F (RF Coax) Conncetor or is the DVD connect to the TV using the Video/Audio cables (either Composite (Red, White, Yellow) or Component (Red, Green, Blue)). I am do however believe this to be a RF tuner problem. Make sure that the TV is set to channel 3 and the cable box is connected to the TV (set to channel 3). What you could also do is get digital cable and use the video output jack as the input to the TV on one of your aux positions.
I would first make sure the tunner is on channel 3 when using the regular cable box, or if you are using the TV's cable ready features make sure the tunner is working correctly, this might have to be done by a qualifide TV repair person.
I hope this helps
Thank you,
Shuttle83
Nov 15, 2007 | Toshiba 57HX81 57" Rear Projection...
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
it sounds like the main board to me, I can purchase them if you want one let me know
May 22, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Ekse
