Question about Schecter 006 Deluxe Electric Guitar Vampyre Satin
I don't know how to change the strings on my shector 006 deluxe, any help please? ive had the guitar a few months now and think it is due a change in strings, however i feel unsure about uncsreweing parts incase i mess up, anybody good with shectors? Thanks if you can help
  • Schecter Master
  • 5,603 Answers
There are instructions on YouTube.com regarding changing strings on guitars. The video illustrations are much better than trying to write in words the proceedure.
Posted on Apr 23, 2010
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
The volume of my 5th string is a fraction lower than the rest on my piezo bridge, i have no idea why, i dont know if a string or battery change could be the answer, it doesnt seem likely, can you help...
Battery change would be my first bet, otherwise the piezo element may not be fully making contact with the guitar for that string, in which case you'd need to take it to a guitar tech who'll be able to tell you for sure.
Feb 20, 2011 | Paul Reed Smith PRS Hollowbody I Electric...
Bought new few years ago. i get adead string only on the b string & only first 3 frets-clears up at 4 fret-g string fine -e string fine. sometimes clears up by itself & is fine 4 few months.If prob...
Sounds like your truss rod needs to be adjusted. This should only be done by a professional. Take your guitar to a shop or guitar store that offers a service like this.
If you really want to do this yourself, though, here's a helpful video that will take you step by step through this:
Hope that helps!
Jan 30, 2011 | Epiphone Les Paul Special II Guitar...
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
Well i can never get a clean sound out of my BC RICH Warbeast NJ Deluxe, i'm assuming it's the bridge but i don't know how to stop it. The buzz gets into every tone i play, need ways to fix this issue,...
The Warbeast is notorious for having buzz problems, and the major cause is usually the bridge. What you can do is:
Standard B.C. Rich String-through bridge - There are two posts, one on either side, that are slotted for a flat-head screwdriver. It is NOT recommended that you try to adjust this with strings on the guitar! Turn the posts counter-clockwise to raise the bridge height. Be sure to turn them the same amount, to keep the string height in relation to each other the same.
Floyd Rose Licensed Tremolo - You will have to adjust the springs behind the tremolo to bring the bridge up slightly above level. You have to have the strings on the guitar to do this To do this, remove the spring cover on the back of the guitar. A phillips-head screwdriver is needed. There should be two screws, one at each end of the spring keeper. Turn them counter clockwise by 1/4 turn each time, following these steps:
1. Turn a single 1/4 turn
2. Tune the guitar.
3. Check for buzz.
If the buzz is still present, repeat steps 1 - 3.
I could not find any other bridge that came with this guitar, so one of these two options should help.
Dec 26, 2010 | B.C. Rich Wmd Warbeast Electric Guitar
I bought a Hagstrom Ultra Swede which sounded very nice when I first bought it but after 3 months I seem to have alot of tuning problems with it. It has been intonated twice and a new set of heavier...
Considerations:
1. Intonation problems can be due to worn strings even if the guitar is set up properly. New Strings can fix this. This is the most common problem.
2. Also, changing string size may effect your set up too. Typically, new guitars come with lighter strings such as (9's) which the guitar is set up for. The positive is that 9's fret easily. The negative is that they bend too easily for some players who either slightly bend them when chording (accidentally), or press too hard on guitars with jumbo sized frets, which in turn bends the string toward the fret board causing detuning. To fix these items folks may suggest you get a heavier string like a (10), but the problem can often be solved by playing with a lighter hand, pressing only enough to make contact with the fret and not pressing the string all the way to the fretboard. Check your intonation using this light touch method and see if it's okay verses pressing the string all the way to the fretboard. If the intonation is okay with the light touch, the guitar intonation is set up properly. You may want to consider playing with a lighter hand or getting a guitar without jumbo frets such as Fender strats etc...
Putting a heavier string on a guitar set up for (9's) would likely cause the buzzing that wasn't there before. In this case you'd need the guitar and neck set up again to accomodate the 10's. So decide what size string you want and set the guitar up for that size.
These considerations are true for any electric guitars.
After consideration of all of the above, you still feel it's the guitar, I suggest you push for a replacement or perhaps credit toward another guitar.
Oct 18, 2010 | Hagstrom Swede Electric Guitar Natural...
Schecter Diamond Deluxe Stilleto Bass-How to Lower Strings
I hope you dident screw it up, a person can realy mess up the platability in a hurry if you dont know what your doing. Lets see if we can get you on a good track .What your looking at is your tali pice. that whitch holds 6 saddels the saddels have horizontal screws. Hex you need a very little alan wrench. they normaly come with a new Ax.string heights are 2.00 at the 5.th and 1.5 on the 1first. use a line of sight to see that strings are in a good line. Never Never screw the vertacal screws with springs. Thisis your intonation. if you mess this up you lose the playabilithy of you gtr. ps Guitars dont come with manuals. check with your local music stoer. find a musician thats will ing to give some hands on tips.
Apr 10, 2009 | Schecter Stiletto Deluxe-4 Bass
"G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
Schecter 006 Deluxe Electric Guitar Vampyre Satin Logo
89 people viewed this question
Top Schecter Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Schecter Music Expert? Answer questions, earn points and help others
