Servis manual printer HP Deksjet F2410I can be a problem HP DeskJet F2410 printer, the print process time will have sound mechanical gears are forced to move, there was a very loud noise
No power even light on my printer 2410 but adaptor cable is ok
what is the problem fuse or what inside
Posted on Mar 05, 2014
2 Suggested Answers
esound
  • 425 Answers
SOURCE: My hp deskjet f2410 printer
Hi, do not have the part numbers handy, but there are 3 small white gears which need to be replaced after you remove the fuser. You can contact metrofuser.com as they have a kit for less than 10.00 that contains all 3 gears. Just tell them you have the f2410 gear noise problem.
This problem can happen because of following reasons :
1. There is some piece of paper / paper clip / sticker stuck inside printer and you are not able to access it. In this case you need to remove all ink cartridges, turn off printer, then turn it upside down and shake it few times. If still not working then you need to open it up as much you can to see if something is stuck
2. Also, you should open up the printer and blow air in it (using compressed air can) to remove all dust. Then take few drops of oil and apply it on the main shaft on which the carriage moves horizontally.
If above doesn't help then the problem is worned out rollers and they need to be replaced. But HP doesn't sell these rollers and there is no set of rollers available that you can buy all together.
You will either have to send it to HP which will be not cost effective or take it to local repair shop. Else you will have to buy those rollers individually from some online store or local store.
Feel free to ask any question or concern you may have. I will be glad to help you.
Thanks for using fixya..
Posted on Nov 05, 2010
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Thanks,
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
How do I remove the cover from an HP Deskjet 5740 printer
No need to open its cover. that is normal, when the print is first start the mechanical parts are re-adjusting and re-alignment its system to start printing.
Sep 11, 2012 | HP Deskjet 5740 InkJet Printer
I am trying to print an email on my HP deskjet f2410 and It is not happening why?
Go into your control panel, and in add/remove software, or under programs & features, look for HP's Smart Web Printing. Uninstall it.
That's it, should FixYa right up!
Jul 24, 2011 | HP PSC 2410 All-In-One InkJet Printer
My printer hp deskjet f2410 blinking and i cant allign the cartridge, how to reset all cartridge (HP60 black and color) ?
Unplug the power cord from the back of the printer while its ON
now Press and Hold
Ok and Cancel button at the same time
While holding them plug in the power cord
Once the printer turns on release the buttons
You will see the Reset message on screen of your printer and in the process it will align the cartridges
Apr 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
Hp deskjet f2410 installer
The installation software for the HP Deskjet F2410 printer can be found at the following site,
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
When you arrive at the site, input your printer's model number (f2410), into the block marked,
" for product" and click the arrow, you will then be guided to the drivers for your printer.
You should be happy with the results.
Feb 01, 2011 | Office Equipment & Supplies
My printer hp deskjet f2410 blinking all..n then i'am can't printing my file..???please help me...
1.Check if there is low ink level in cartridge
2. Check if there is any piece of paper stuck inside
3. Unplug the power cord while its ON , Press and hold OK and CANCEL at the same time, while holding them plug in the power cable and then release the buttons.
It should fix the problem
Jan 03, 2011 | HP PSC 2410 All-In-One InkJet Printer
My hp deskjet f2410 printer makes loud noise while printing. what could be the cause and how could I fix it?
Nov 05, 2010 | Office Equipment & Supplies
I have a HP DeskJet 540. Not printing
I've just fixed a Deskjet 420 with the same problem.
In my case the printer had not been used for several years, when I opened the printer lid I could see that the ink had leaked out of cartridge and solidified around the print head. I was able to manually move the printhead out of the way, VERY gently brake up the solidified ink with the end of a screwdriver, after repeating this process a number of times and installing another ink cartridge I had a working printer salvaged from the junk in my garage!
Jan 11, 2009 | HP DeskJet 540 InkJet Printer
652 people viewed this question
jasbo
jasbo
