Question about Amana 24 in. DWA22A Built-in Dishwasher
Crud & crumbs left on dishes - Amana 24 in. DWA22A Built-in Dishwasher
  • 4,066 Answers
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
Here are your diagrams and parts. I noticed a filter and trap which could be your problem. Make sure the water is spraying out the spray arms good.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=20680&diagram_id=676283#d676283
Posted on Apr 23, 2010
No removeable crumb tray located as shown & listed in manual
The tray may have been forgotten during assembly. Toaster oven crumb trays often simply slide in and out; there are no tracks. Put CEM on autodial and keep trying until a human being answers. Consider getting a crumb tray from some other brand and using it
May 31, 2013 | CEM Global Toaster Ovens
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Dishes not getting clean. Rinsed off dishes have crud on them after its run
Sorry, I don't have experience with that problem & I'm limited to my experience - I'm not an appliance repair person, just fixed what went wrong with mine & yours sounded kind of similar. I'm sure someone else can help you out.
Nov 17, 2009 | Electrical Supplies
Dishes are not getting clean..glasses are covered in crud
Try refilling the rinse agent, and cleaning out the bottom of the unit. If the dish washer was resently installed. Or you have recently intalled or replaced your garbage disposal. Make sure the plug was punced out where the drain from the dish washer connects. If the plug is not punched out you will be useing the same water over and over agian.
Jul 20, 2009 | Dishwashers
HOW TO SEPARATE PUMP FROM MOTOR
There are 4 bolts on the back of the Haight pump on both the 5 or the 8 gpm model. Remove these 4 bolts and using a dead blow hammer, give the pump a sharp blow to the top then the bottom & this should seperate the two. 90% of problems with these pump & motor assy's are from poor oil filtering practices, not having the crumb catcher in place & crumbs getting past the paper & into the pump. The tolerences between the two cams are very tight & believe it or not, a pencil eraser size bunch of crumbs can jam this pump. I go on 3 calls average a month on Dean fryer pumps and after they sit there and run/hum and trip the pump breaker, you WILL burn the motor up. I have a perfectly good used assy from a Dean fryer if needed.
captrick
capt_rick1912@yahoo.com
Jul 20, 2009 | Frymaster Dean H14 Deep Fryer
Salty white dishes
Pour white vinegar into the rinse cycle, this should help.
Apr 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have a maytag mdb4000aww dish washer. The dishes aren't getting consistently clean. I wanted to clean the trap/filter. There's two ports towards the front side. The one on the right i was able to...
Hi
The port on the left is the float it has no filter don’t try to remove it. To get your dishes cleaner: step one, each time you wash run the tap water in your sink till it’s hot. Step two, buy what’s called “dishwasher magic” use that every 2-3 months. Three, use rinse aid. Four, check the sprayer arms, make sure all the holes are clear and that they spin freely when the dishwasher is loaded. There is the possibility that the interior motor area needs to be cleaned, if you’re handy you can remove the lower spray arm and the cover, lift that up to expose the interior motor area, this is fairly involved, if you’re not comfortable you should call for repair, it shouldn’t cost too much.
Apr 01, 2008 | Dishwashers
Dirty dishes
YOUR PUMP IS DIRTY NEED TO CLEAN
Mar 05, 2008 | Maytag MDB9100A Dishwasher
Amana 24 in. DWA22A Built-in Dishwasher Logo
202 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
