Question about Maytag Atlantis MDE6400AY Electric Dryer
Cannot open the lid on a maytag dryer (1999 model year, model # MDE6000AYQ) as it doesnt appear to have the plastic little tabs, as some others i have seen done online? as i need to replace the belt. thanks
    President:
  • 949 Answers
Here is how to remove the front and the top.
-Open the door, remove the 4 screws, (2 from the hinges and 2 from the open side of the door that are opposite the hinges)
- Pull on the front top of the front panel from both sides it will release and then lift the entire front panel off
- you may be able to get to the belt from here, but if not remove the two screws close to the top that hold the green clips from the front to the top and remove the green clips The top should be free
-lift the door off the frame and set aside.
- you should be able to see how the rest comes apart from there
Posted on Apr 24, 2010
Machine will not start
THE MOST COMMON THING WITH THIS WASHER IS THE LID SWITCH. THERE IS A TEMPORARY & EASY WAY TO FIGURE THIS OUT. FIRST OPEN THE LID. LOOK AT THE BOTTOM JUST A LITTLE RIGHT OF CENTER WHEN THE LID IS UP. DO YOU SEE A LITTLE WHITE PLASTIC PIECE? THIS IS THE STRIKE FOR THE SWITCH. IF IT IS MISSING YOU NEED THAT. IF IT IS THERE LOWER YOUR LID SLOWLY UNTIL CLOSED ALL THE WAY. LISTEN TO HEAR A CLICK WHEN DOING THIS. A CLICK WILL DETERMINE IF THE SWITCH IS BEING ACTIVATED AND THE POSSIBILITY THAT IT IS GOOD. IF YOU HEAR THIS CLICK AND THE WASHER WILL NOT START THEN YOU MAY HAVE A TIMER ISSUE. IF YOU HAVE NO CLICK THEN CONTINUE. UNPLUG WASHER. REMOVE THE 3 SCREWS AT THE TOP OF THE CONSOLE. WITH ONE HAD ON THE CONSOLE TOP CENTER STARTED TO PULL FOREWARD. PUSH BACK AT THE BOTTOM CENTER WITH THE OTHER HAND. THE LID SWITCH HAS 2 RED, 2YELLOW, 2 WHITE AND 1 BLACK WIRE TO IT. UNPLUG THIS. ON THE BACK LEFT CORNER OF THE LID SWITCH THERE IS A LOCK TAB. WITH ON HAND LIFT THE WASHER LID UP 3 INCHES OR SO. WITH THE OTHER HAND LIFT THE LOCK TAB ON THE LID SWITCH WHILE PULLING FOREWARD ON IT. PUL LID SWITCH OUT AND PUSH THE PLUNGER IN. DOES IT CLICK? IF YES THEN FIND A VERY TINY SCREW TO SCREW IN THAT END OF THE PLUNGER. YOU ONLY NEED TO EXTEND THAT PLUNG LESS THAN 1/8 TO 3/32NDS OF AN INCH. YOU CAN ALSO GLU SOMETHING TO IT. REASSEMBLE ONCE THIS IS DONE.
Apr 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag dryer LDE5004ACW not turning how do I open to check belt? Solution #1 doesn't explain how to ''pop the top'' ? There are tabs underneath lid in the front but pushing them in doesn't allow lid to be...
Yes, on your model, the front comes off first. Check the front of the dryer for two phillips head screws, about ankle high, one on each side. Remove them and pull front panel up from bottom, then un-hinge it from the dryer's top. Dryer top will not have to come off. After you take the front panel off, you will be able to take four screws out of the front drum support frame to allow that to be removed if tyou want to change a belt (or remove the drum).
Nov 29, 2009 | Maytag Dryers
I have a Neptune model MDE9700AYW dryer that wont start
Check to see if the little tab in the door jam, which causes the dryer to turn off, is broken or bent. If its bent you may just need to bend it back.
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune toploader interlock system "tabs" broken
HI, You should replace it. It is for safety reasons. Please get me your model # and I can get you part# info and how to replace it.
Thanks
Vic
May 17, 2009 | Maytag Neptune Washer
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Washer
TAKE A LOOK AT YOUR LID SWITCH MAKE SURE PLASTIC PLUNGER IS MAKING CONTACT,, SHOULD MAKE CLICKING NOISE WHEN OPEN AND CLOSE LID
Nov 29, 2008 | Maytag Performa PAV2200
Top load lid repair
put one of the plastic balls in place on one side of the lid, hold the lid against it to hold it in place. then put the other ball in the other side indention and push the lid down on it until it pops in place. it is a little tricky if you have never done it b4.
Jun 27, 2008 | Maytag SAV2555A Top Load Washer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Jan 30, 2008 | Maytag MDE9316 Dryer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Atlantis MDE6400AY Electric Dryer Logo
333 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
