Question about Monster Cable MCC AVL300-S Remote Control
Trouble charging Monster MCC AVL300 battery
I have trouble getting the Monster MCC AVL300 universal remote to enter charge mode when I place it on the charger.
Had same problem, and others have as well. It's not the contacts, but the design of the cradle - the contacts on the unit don't even touch the contacts on the cradle. The only way we get ours to charge is to balance something heavy on top of the remote while it's on the cradle to force the contacts to touch. We use a vase that's on the coffee table, believe it or not.
Posted on Jun 02, 2010
I was also having the same trouble. The charger isn't designed very well. But I did fix the problem.
I used a 60 watt plug in soldering iron(not a trigger/gun style) with silver solder and made 2 perfect bubbles(same shape) on top of the contacts on the charger.
Fixed!
Posted on Nov 08, 2011
    Genius:
  • 1,274 Answers
Try cleaning the contacts with contact cleaner......hope this was helpful....
Posted on Apr 23, 2010
Have same problem. Periodically crape the contacts with your thumbnail, tiny amount of crud build up severely impacts ability to charge.
Posted on Jul 22, 2010
Bought a universal charger with adjustable contact that hold the battery in place then you csan charge many different kinds of batteries. Purchased ay nest buy or London drugs or best buy take the battery out of the remote and show the sales rep.
Posted on Aug 11, 2013
Mine just stopped working. Can it be reset?
Take the battery out from it compartment. The remote control will reset itself after some time. The re-insert the batteries, and check the remote control for its infra-re emission.
Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Nov 24, 2014 | Monster Cable MCC AVL300-S Remote Control
Remote will not turn off tv
reset you code again. download from www. remotecodelist.com and try again.Replace batteries with the same type, and clean it the contacts batteries with c. cleaner.
If the problem persist, maybe you have a faulty Syscom,go to the repair shop TV for fix it. see the diagram
God bless you
Nov 14, 2012 | Monster Cable MCC AVL300-S Remote Control
Can Monster AVL300 control Bose Lifestyle
Sure it can control the Bose system. Some how I find this remote compatible with a lot of devices but it won't function with the most common devices like a Blu ray DVD player. It won't even turn it on or off. So try and let me know if it worked. Good luck.
Mar 27, 2012 | Monster Cable MCC AVL300-S Remote Control
Charging dock wont charge remote any longer
Hello Sir, hi, we need to know where the trouble is, we have 2 to test, the charging dock and the remote control. to test the charging dock you may need to measure the voltage output of around 5 to 12 volts of the dock using a voltmeter usually used by a technician, Its easier if a friend has another dock. Or get another charging base. follow this link. http://www.amazon.com/Compatible-Battery-Logitech-Harmony-Remotes/dp/B002SLP3X8
Sep 20, 2010 | Logitech Harmony One Advanced Universal...
How to get flash mode off a phone
How to fix Motorola Flash Mode Of Death To do this you must have a fully charged batery, i know when your phone is stuck in flash mode you cant charge your battery so your gonna have to buy a new one or try to charge the battery i another phone.
First download Motorola RSD Lite 3.2 from here http://www.cpfxwireless.com/downloads
Then download the Monster flash file from here http://www.cpfxwireless.com/downloads (Same place i no)
Then extract your monster flash file, save it to somewhere on your computer.Plug in your phone when on motorola flash mode .Open RSD lite , find your monster flash file wherever you saved it then click on start. You can always use the Motorola Software update , but i already had the latest software on my phone so there was nothing to update
Jun 29, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
I have a harmony 880 remote. Won't charge now.
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
Dec 11, 2009 | Logitech Harmony 880 Universal Remote...
My harmony 880 will not charge
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show2_bing.gif should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
Dec 02, 2009 | Logitech Harmony 880 LCD Remote Control
Dead. When I put on charger I get no response
Dec 01, 2009 | Logitech Harmony 880 LCD Remote Control
Monster Cable MCC AVL300-S Remote Control Logo
1,821 people viewed this question
Top Monster Cable Televison & Video Experts
Electro Med Services...
Are you a Monster Cable Televison and Video Expert? Answer questions, earn points and help others
