Question about Foxconn K8M890M2MA-RS2H Motherboard
Will not Post. No video at all.
Fans work, HDs spin up but nothing else. I've tried a new processor, tried taking out memory no beeps, in fact I get no beeps for anything I do. I know thw speaker works because when I received the system from the person the processor was not completely seated and it was beeping.
    Novelist:
  • 128 Answers
You will have to diagnose it by trial and error. You will need to plug in a different processor, and try it, if no joy, try different ram, if no joy, try different video card, if no joy, try different power supply. Or try each of those listed in anoother system one by one. Problems like yours can be time consuming to diagnose. You will have to determine which piece of the puzzle is causing the problem. You may have shocked the motherboard, ram or processor and they could be dead.
You also said that the processor was not seated correctly, that could have burned up the processor, also look to make sure that you havent bent one of the pins over on the processor while re seating it. It is easy to do if you are not paying attention.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!
Posted on Apr 23, 2010
Try Putting some know working ram. also try another Video card, Make sure the CMOS jumper is set to hold data
P5GD2 one post beep
Check the processor's heat sink fan. Make sure it's spinning. Blow out any dust or vacuum (w/ no power to the tower.) Reseat the memory. Try with one memory stick if you have two, resassuring to put in slot 1. Sometimes two different types of memory act weird together. Make sure memory is compatible. (ex. PC2100...)
Jan 01, 2012 | ASUS P5GD2 Premium (P5GD2PREMIUMWLOM)...
I'm new at building PCs, but once I got all the hardware installed and turned it on, I could get no video output. I tried with the motherboard video and then with a PCI-E video card and neither would...
Sounds like something like your ram or processor are no good yet.
If it doesn't give any kind of beep, start over, with just ram and processor, and keyboard.
and oh, yea, monitor.
Please rate this answer.
Aug 04, 2011 | Biostar G41DVI Motherboard - G41 Express,...
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
K7VM3
An ASRock K7VM3.motherboard is a socket A (462) board specifically for the AMD processors. To my experience, these boards (due to age and period of usage) are prone to:
  • bulging/leaky capacitors of the high current regulators near the CPU;
  • the heatsink tends to be dislodged/misaligned causing overheated processor;
  • loose memory slots causing defective memories.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | VIA ASRock K7VM3 Socket A/...
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
New computer won't POST
have you tried different memory as no matter what the board says they don't like some memory .
also take the board out of the case and connect pwr supply.
cpu and fan ,video card , and 1 memory stick
no cables ,keyboard ,mouse or drives connected.
this is called bread boarding.
reset the bios jumper, then put jumper back.
and power up.
Mar 31, 2008 | Computers & Internet
Power light and fans come on but no post or boot up
if the mother board has an integrated video card, try to connect the monitor on that, and than enter BIOS to activate the PCIe video card ...
(if this is not the problem give more details, any beeps made by the comp ... have u checked all connections ...)
Mar 10, 2008 | Intel Motherboard
PC won't boot
Is the case speaker connected to the motherboard?
If it is, do you get any beep sequence? If there is no display, the power speaker output an audible beeps sequence. For example, 3 short beeps mean a problem with memory.
Keep posting here to zoom in on the solution.
Dec 28, 2007 | PC Chips A21G Motherboard
No post no beep no video
you sure that the 4pin power connector coneected to your mobo
Sep 12, 2007 | Computers & Internet
Foxconn K8M890M2MA-RS2H Motherboard Logo
166 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
