Memorex model MT1191 channels locked
My tv has some channels are locked and it ask for a code to unlock it where can I fine this code
1369 is the code
Posted on Oct 30, 2008
How to disabled key lock on ultra samsonic television
Hi, I don't actually know how to unlock your specific TV. But here is a basic guide to unlock your tv.
    1)Turn on the TV and grab the remote.
    2)Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This should unlock the channel. This is an option for people who want the TV to stay locked out, want to be able to bypass the lock to watch a certain show or channel. All others channels will remain locked and the TV will fully lock when it is turned off.
    3)Unlock all of the channels on the TV by entering the factory reset code. There are 3 main reset codes that TV Manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will factory reset the TV.
    4)Call the technical support service number in your owners manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure you have the model number and the serial number.
    5)Or take it to a TV repair shop.
How to Unlock TV eHow
Dec 27, 2015 | Ultra Computers & Internet
Model name for alba tv
It should be a plate in the back of the TV with model number and serial number.
Other brand that use the same code that Alba use are: Accent, Aiko, Aim, Akai,Akiba, Allstar, Ansonic, Audiosonic, Curtis, Daewoo, Dansai, Goldstar, Grundig, Hair, Hitachi, Lenco, Leyco, LG, Memorex, Philco, Noblex, Panasonic, Piooner, Philco, Phillips
Dec 03, 2009 | Televison & Video
How to unlock some channels that locks by mistake on your remote?
is it a cable channel that is locked or a normal TV channel ??
if its the cable channel, you can always call your cable company and have them give you the unlocked code...
if its the TV channel... what make/model is your TV ?
Feb 17, 2009 | Daewoo DTQ-13P2FC 13" TV
Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
Mar 24, 2008 | Panasonic CT-24SX12 24" TV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Help! How can you unlock a pin on a TV that you don't know?
Tried unplugging it for five minutes then plugging it back in? It resets the software.
Sep 09, 2007 | JVC AV-27020 TV
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
