Question about SkyScan 86709 Atomic Wall Clock
How do you reset the model 38229-1 clock time zones
  • 8,197 Answers
1. press "MODE" (it will show the alarm time) 2. press "ADJUST" (this will switch the time zones) 3. when it is on the desired time zone, press "MODE" to return to the clock.
Posted on Apr 23, 2010
How do you set the alarm clock for a model:38229-1 clock
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Aug 22, 2011 | Audio Players & Recorders
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
Mar 15, 2011 | Audio Players & Recorders
Lost manual, how do you set this device
I have a model 38229-1 atomic clock can't remember how to change location from one time zone to another on pac need eastren
Dec 11, 2010 | First Alert 7 Day Vacation Timer Model...
Atomic clock is 2 hoursfast
You need to reset it to YOUR time zone. The default on this model is Pacific Coast time so you must be in the Central Time Zone (2 hours ahead of Central). Instruction manual should show you how to reset.
Feb 09, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Need instruction for setting clock model # 38229-1 Atomic Clock - Sio/Scan (Equity Time). Need to set time, time zone and date. blainep
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Nov 29, 2009 | Audio Players & Recorders
Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Feb 08, 2009 | Oregon Scientific Starck Large Music...
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
673 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
