Question about Refrigerators
I have a Kenmore Refrig Model # 106.56532400. I have replaced the compressor, thermisters, evap fan motor on this thing. It is getting down to 34 below and It's just too cold. Can you tell me what else needs to be done?
  • 1 more comment
  • Steven Humphrey Apr 23, 2010
    Hi
    To clarify: I replaced ther thermisters or temp control sensors as some call them. The refigerator side is working fine and the flap is working perfect. The freezer section is at 34 below and staying there.
    Thanks
    I'm hoping this is not the electronic conrtol on this refrig.
    Thanks for your help. It seems none of this has helped on this thing. I guess it's time for a new one
  • 661 Answers
Lets clarify a bit. You replaced the thermostats? The part the adjustment dial connects to?
And it is getting 34 degrees below zero? In the freezer part or the fridge part?
Honestly I like to keep our freezer portions to around 20 degree F. and the refridgerator to 33 or 34 degrees depending on how well it circulates air. At that temp Milk will keep double its expiration date.
To help you though I need to know what the temps are for the freezer and the fridge. Then I need to know what temps in each you are looking for.
Generally you start your temp selection in the freezer because the fridge just gets air bypassed from the freezer. There should be an air control door between the two compartments.
Posted on Apr 23, 2010
  • Bryan Fullerton
    Bryan Fullerton Apr 23, 2010
    Have you allowed this thing to do a a full defrost? Sometimes things will get frozen due to high use that is just too much for the frost free feature to handle. Try to use up your perishables and then unplug it and let it sit overnight. Make sure to have water evap trays empty and ready to go. Sometimes this is a simple fix and sometimes not. depends on how much money you want to spend. No matter what though as techs we cant help without the right information. Reference my earlier questions.
  • Bryan Fullerton
    Ok thankyou fixya. finally updated. I see the fridgerator is working fine. thats good. and you have the freezer turned as warm as possible . Which is basically set at 1.
    Try setting the fridge part to be 34 or 33 degrees. The cooler it is the more cold the freezer has to share.
    If that doesnt help then the control board is not reading the temp sensor for the freezer.
  • 17,970 Answers
I understand that you have a refrigerator or freezer that is cooling, but cooling poorly? Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. May have a problem in one of several areas:
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch) The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Hope help with this; tell us news.
Kenmore Elite fridge cools but we noticed the compressor and fan never turn off. Compressor is very hot to touch. Do we need to replace compressor or a relay switch or ...? Thoughts/suggestions?
Newer refrig. Run almost continuous but you could try cleaning the condenser coils, located on back with vacuum and brush also place thermometers in freezer and mid level refrigerator, freezer should run 0 to -8 F and refrigerator 34-37 F. If much lower adj. thermostat up.
Sep 16, 2017 | Kenmore Refrigerators
Low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
Just replaced evaporator fan motor and plugged back in and coil getting cold and compressor working when should fan kick in
On some Kenmores it'shas a fancy term;it is called Pre-Chill. The compressor and compressor fan comes on but the inside fan does not till the evap chills down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 07, 2011 | Kenmore Side by Side Refrigerator
I have a GE refrig. model GTS22ZCMARCC. The evaporator fan has been pulsing up and down forever. Then the freezer stopped getting cold and the refrig. part was not as cold. I check the evaporator fan...
it's the board,also change out the sensor that's on top of the coil,it looks like a white bullet,the part number for the temp. sensor is wr55x10025 and the board is WR55X10942.everything runs through the board,i've seen when you call for water the compressor stops or the water doesn't dispense,or the fan pulsates like you have.let me know how you make out
Oct 21, 2010 | GE GTS18SHPBS Top Freezer Refrigerator
Have 8550510 Kenmore Refrig that stopped running.
Sounds like the thermostat is bad . Without the complete model number , including the first 3 numbers , such as 110. , 106. , 253. etc , I can't tell you how to access it . If you can get access on your own , jump the 2 wires connected to the thermostat , and see if the compressor cuts on . If so , replace the thermostat .
Oct 20, 2009 | Refrigerators
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Kenmore fridge not getting cold
first thing to heck would be the condenser fan motor which is located int the compressor compartment pull the refrig away form the wall remove cardboard cover and inspect the fan motor that you will see. check for obstruction or if the fan motor is seized. if this motor fails it will cause the compressor to run extremely hot then shut off on internal motor protector. if you determine the motor is bad you can place a house fan behind unit blowing on compressor area to keep unit working until you get it repaired.
Thanks Peyton
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Dec 18, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
