Program a Raynor Garage Door Keypad
My family and I have fecently moved into a new home which has a Raynor Garage Door Keypad (model# 66LC) but we do not have the code. How would I reset the keypad?????
  • 28 Answers
You need to locate your learn button. It will be located in the receiver box ( on the back of the motor, with a wire hanging down), Pop off the Nameplate on the receiver box. you will find a green yellow or red button. push the button and an LED comes on for about 30 seconds, during the 30 seconds go to keypad, enter a new 4 digit code. press and hold the enter button on keypad. DONE Note: if you have sensors on your door, you do not want to walk throught them, or the keypad will not program
Raynor Can help
Posted on Jun 09, 2010
Peroubeleme belotooh pc lenovo k 41
Posted on Apr 23, 2010
I have an older liftmaster 66LC remote keypad that isn't working, which models will work? My garage door opener is a Chamberlain 1160hypen4 with a manufacturing date of 9/92
as long as your opener has a smart button any of the universal keypads made by chamberlain/liftmaster will work. such as the as the Liftmaster 387 or the Chamberlain Clicker.
Mar 06, 2015 | Building Materials
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need a replacemnt for raynor keypad model 940C/67LC. Sure would like to find one. thank you r
If you go to this website you will find a dealer in your area.
http://www.raynor.com/searchus.cfm
Jan 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Raynor Keypad does not work
There should be a small screw about 3 inches up from the bottom. Remove this screw and the cover should slide off.
Oct 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Courtesy light not going off
This is usually caused by electrical storms. Electrical surges seem to get to the small relays that control the light and fry them.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reprogram keypad remote
Setting the code:
1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal indentification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Apr 25, 2009 | Computers & Internet
Raynor navigator garage door opener won't work in bright sunshine
WOW I NEED TO RAISE MY RATES!!
I DON'T KNOW THE RAYNOR PRODUCT. HOWEVER, WITH MOST OTHER BRANDS THE PROBLEM YOU DESCRIBE CAN BE SOLVED BY SWAPING THE POSITION OF THE SENDING RECIEVING EYES THUS GETTING THE ONE THAT IS BEING AFFECTED IN THE SHADE
HOPE THIS HELPS
Apr 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reset garage door code
Hi, The opener, remotes and keypads have a set of dip switches that you can use to change the code. You will find the switches when you open the remotes and keypad and are in the back cover ( depending on the model) of the opener itself. Make sure that the codes of all the switches are set exactly the same. If you need additional help let me know! Good Luck.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Raynor 1245rgd navigator learn button blinks
5 flashes on operator and the short movement on the door indicates a bad RPM sensor. try to unplug the unit for 30 seconds, if this does not reset the motor, replace the RPM sensor
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Computers & Internet Logo
1,241 people viewed this question
David Payne
David Payne
