Question about Frigidaire Washing Machines
Fridgiaire front load washer goes through all cycles fast with no washing or spinning dry.It only lets water in and pumps out.
  • 2 more comments
  • dovetaildad2 Apr 23, 2010
    On short cycle it only lasts about five minutes.Actually it is only about five minutes on all cycles. Model number is CEH1642FSO. It was purchased brand new on May 5 2007. At start of cycle water comes in, no washing done and then pumps out and in and out and end of cycle.
  • dovetaildad2 May 02, 2010
    You are not even close to being right. What a waste of money.
  • dovetaildad2 May 03, 2010
    The problem is solved no thanks to you. What more information would you need?
    Your advice to me cost me x number of dollars and didn't help. Am I supposed to help you for free? Not likely since it cost me again to have the problem solved correctly.
    President:
  • 1,554 Answers
The pressure switch is probably not tripping causing the control to activate pump to pump out the water to prevent flooding. The timer or control can also be bad depending on the model of the washer. Specify the model number of the washer for accurate troubleshooting. Further information can also help easily determine the source of the problem and necessary action can be advised.
We base our findings with the information given; therefore, limited information limits the chance of determining the source of the problem.
How long the cycle last?
Posted on Apr 23, 2010
  • 1 more comment
  • Jahn27
    Jahn27 Apr 23, 2010
    It is indeed a faulty pressure switch because when the water level reaches about 4.5 inches from the bottom of the spin basket, the contacts for the water inlet valves opens and the contacts providing power to the other components closes. Failure of the water inlet valve contacts to open will cause flooding and the pump is activated to prevent it. On the other hand, if the contacts for the other components fails to close, the washer will not go through the wash and the spin cycles.
  • Jahn27
    Jahn27 May 03, 2010
    My apologies for that; we are just making the conclusion based on the information that the client give us. Limited information limits the chance of having the cause problem determined. It's been more than a week since the problem is posted and nothing came from you after the last communication and it is assumed the problem is resolved. But we are still willing to help you; we just need a good and a constant communication to keep track of the development. Just keep in touch and provide further details regarding the problem.
  • Jahn27
    Jahn27 May 03, 2010
    We would be grateful if you can share to us what was the problem and how it was resolved. It will enable us help other users who will experience the same problem as yours.
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Will not spin out at end of cycle
if there is till water in there the drain pump may be clogged.you need to use a wet dry shop vac and attch it to the end of the drain hose then drain out the water. remove the two screws on the bottom of the washe pull down the front panel. then remove the two hoses on the pump and look for the blockage.i hope this helps with your problem.good luck let me knwo how it goes
Jan 23, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Side load washer spins cycle problem.
Clean your drain valve. The water is not pumping out. This puts a strain on the machine.
Remove the bottom front cover to access the drain valve.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
