Question about Acer Aspire 3610 Notebook
Laptop not working
I don't understand what you mean by brick? Shouldn't my laptop work without the battery in and it being connected to the adapter? The battery is a 14.8v-2000 mAh
    Genius:
  • 1,027 Answers
The Brick is the external power adapter, My acer uses model # ADP-60XB 19V X 3.16A= 60 Watts
Yours I believe is also a 19V but I believe the amps are 3.45 making yours a 65Watt power supply ac/dc adapter.
Test the voltage, if your unsure how, take it to Radio Shack and have them do it.
Posted on Mar 23, 2008
SOURCE:
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
Without battery but with POWER ADapter in ACER ASPIRE ONE AOA 150 DOES NOT SHOW any litGHTS on my ON OFF siwtch too Does not blink or show any liGHt. Battery GETS CHARGED an carGING liGHT turn amber and...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 05, 2011 | Computers & Internet
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
Jan 12, 2011 | MXR Stereo Chorus Pedal Guitar
My Lenovo s10 power adaptor (Input 1.7A, Output 20V 2A) was working just now together with the battery. After i didn't used the laptop for an hour and returned to switch it on, the power adaptor isn't...
hi,
You said laptop is working fine if just using the battery,that means that there is nothing wrong with the battery itself. Can yu please try to connect the laptop directly to the power outlet without using the battery just for the mean time,remove the battery and connect the AC adapter directly to the power outlet then power on the laptop,if nothing happens,that means that there is something wrong with the AC adapter itself or the power port on the laptop.
Jan 09, 2011 | Lenovo IdealPad S10 Laptop AC Power...
We noticed today that the battery does not charge, nor will the laptop operate with only the power adapter connected. I've verified that the power brick is putting out the correct voltage. If I...
Check if the AC Adapter brick is getting warm when connected, if not then you need to replace the Adapter.
If AC Adapter brick is getting warm and still its not charging the Battery, please perform the following steps.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Note: With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
The procedure to remove this static charges from the notebook is known as power drain.
Performing a power drain procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
If issue persists, contact Notebook manufacturer for further support.
Oct 15, 2010 | Computers & Internet
Toshiba portege s100 without battery
in can work even no battery pack. using your power adapter.
Apr 15, 2010 | Toshiba Portege S100-S1133 Notebook
Will not receive a charge
Look at the bottom of your laptop on the Dell sticker and look for a rating like this 19.5 volts @ 4.62 amps if your power brick is the PA10 heavy duty one.
The smaller power brick PA12 is only rated at 19.5 volts dc @ 3.34 amps and you would not believe how many Dells were shipped with the smaller power supply and the laptop needs the one rated for 4.62 amps. I have found this on many laptops I have serviced for folks who just have the wrong power brick for their laptops. This is a common cause of the battery never reaching a full charge or just not charging at all. Also, could be a bad motherboard too! Check out the ratings on your laptop sitcker and then look on the charge for the rating there too. They must match!!!
Nov 07, 2009 | Dell Inspiron 8500 Notebook
Laptop not working
Do you have a different power brick to use? Sounds like the brick output no longer supplies the required voltage/amperage.
What is the DCV power output and Amperage of the brick?
and what is the Part number of the brick
Mar 23, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
75 people viewed this question
Ekse
Alun Cox
