Question about DCS RDS-366 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
My stove is stuck on the clean cycle and the door is locked. I hit the button by accident.How do I unlock the door.The racks are still in the oven and don't want it to continue on the clean cycle. I turned off the power. What do I do ??
  • DCS Master
  • 43,501 Answers
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 28, 2010
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
    Thank you and thanks for using fixya
    Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
    The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
    stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
    Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
    Oven Lock stuck open before start of self-cleaning cycle
    Sounds like you bent the door where the lock is. You might have to replace the door.
    Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
    Jenn-Air stove locked
    After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
    Dec 10, 2008 | Ovens
    Jenn-Air S160
    I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
    Thank you!
    Sep 06, 2008 | Kitchen Ranges
    push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
    Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire stove door locked
    I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
    May 10, 2008 | Frigidaire PLEF398AC Electric Kitchen...
    Door Keeps Locking and Unlocking after Power Outage
    Located the switch - resetting fixed my stove as well.
    Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
    LOCKED DOOR (but it's not!) GE JKP85
    bob, sounds like the door lock cam is making the door lock switch. Either the switch actuator stuck in or the cam failed to home. The cam has 2 funtions, one is to position the lock hook in the door and the other is to tell the board whether the door is locked or unlocked. On a single or upper oven the assy. is behind the control panel. For lower ovens the assy. is behind the trim between the two ovens....Catriver..post back.
    Apr 06, 2007 | GE Profile JT955SFSS Electric Double Oven
    DCS RDS-366 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
    179 people viewed this question
    Top DCS Kitchen Ranges Experts
    John Tripp
    John Tripp
    Paul Carew
    Sal DeAngelo
    Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
