Question about Epson Artisan 800 All-In-One InkJet Printer
Black lines in pictures printed from Artisan 800
When I try to print from computer or when I make a picture copy there is a black line that runs across the photograph at every inch
I have the same issue, It seems 1 line of pixels is overlapping with the next set of pixels and makes a dark line horizontally.
Posted on May 29, 2010
  • jeffokada81 Feb 06, 2011
    Found solution. Call Epson, tell them about the HIGH-SPEED printing issue of lines/bands or horizontal lines during fast print and they will send you the Artisan 810 upgrade model FREE.. They will send you a return box for the old printer. You can either send it back or keep it . doesn't matter. All they need is the serial number for your 800 model printer.
    The Artisan 800, just print a low or standard speed by unchecking the 'highspeed' check box in printer preferences.
On Epson Artisan 800 the scanner leaves wide black stripes for the whole length of the paper. Printing From a file is OK.
If computer printing is fine (source) but scanner printing has problems, then of course, your problem is in the scanner. The only solution based on your info (which is good), are the lines in the same areas on other bad scanning prints? If so, your problem means that the scan-head has a connection problem leaving a 'black' send to the print buffer. This will require some technical repair replace or clean connection. Remember that this is a mechanical movement that not only records what it 'sees'e but at what X-Y location the read was 'seen'. It would be worth it to get an estimate from your local computer repair center give you an estimate.
Sep 22, 2014 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 810 prints vertical black lines on all documents
this problem is usually fixed easily. this commonly occurs when print head is clogged. I use a facial tissue and alcohol to clean the head with the ink cartridge in an upside down position (if possible) then i print one or two test prints to get it back to normal.
Jul 06, 2014 | Epson Artisan 800 All-In-One InkJet...
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson Artisan 800 prints only 1 inch of anything and then spits the paper out
Try the following to resolve this issue.
1. Check if same issue appears when using your Artisan 800 as a standalone copy machine.
2. Try printing from a different application to isolate the issue further. You can also print a windows test page to check if this issue is caused by the application that you are printing from or by the printer driver.
3. Reinstall Printer Driver.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
My Artisan 800 only prints the top inch of the page - the rest of the page is blank. This is true regardless of the function: print or copy or fax, so I don't think it's related to the computer. Ink...
My Artisan 800 was doing this and I realized it was because I was using three hole punched paper. I think the printer sees the top hole and thinks the paper has run out and cancels the rest of the page. Big engineering goof Epson.
Dec 17, 2010 | Epson Artisan 800 All-In-One InkJet...
My printer has problems printing dark colours. When printing pictures or text, it leaves horizontal lines on black only. I have a continuis ink system which has lots of black. Any ideas?
Try changing the print paper type to something other than plain paper. Use the matte paper setting, or the photo glossy. The printer will lay down more ink at these specialty settings.
Jan 24, 2010 | Epson Artisan 800 All-In-One InkJet...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Black lines running down the prints
it seems that your print head is the problem you can try to clean it first..
but if you already try to do this no other choice is to have a service center o change it for you.
thanks,
Mar 20, 2009 | Sharp AR-M450N Copier
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Epson Artisan 800 All-In-One InkJet Printer Logo
893 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
