Thats description of the symptom, isn't much to go on... The FIX below,may or may NOT apply, still it is amazing how many times it works. If that;s not a fix, then, please use the Service Manual, and links below.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
If it is NOT that, please use the Service manual to troubleshoot and repair.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdfAbove is a Service manual, troubleshooting and repair.
http://www.applianceaid.com/dishwash.html
http://www.repairclinic.com/Dishwasher-Repair-Help
Above two, are repair DIY links, these will help you isolate the problem.
HI. In order to answer correctly, I will need the entire model number of this unit. this is the only way you can receive proper service and correct answers.
Please post this needed information, asap.....
Hello, the fix with the symptoms you mention is to replace the circuit board. Joe
Hi
Thanks for using FixYa. Please check for the following if your dishwasher
is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring
connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board
faulty.
4. Motor (inoperative, check
resistances).
5. Door switch (open contacts).
6. Door latch not making contact
with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate
when START or OPTIONS is depressed.
Please do accept the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
fuses are fine door contact ok
new cicuit board still the same problem
model no is adp4501/5
