Question about Video Game Consoles & Games
I am trying to set up an x box on my tv but cannot get a signal is it because I have freeview?
  • sgrady399 Apr 23, 2010
    No I have Freeview connected to the TV but when I connect the X Box using the Red White and Yellow Leads the X Box switches on but there is nothing on the TV screen
  • Scott Frye
    Scott Frye May 11, 2010
    Is it the Xbox that says you have freeview? Can you delete freeview from xbox if it's there?
  • 51 Answers
No absolutely not...if you have xbox and freeview connected to tv they will be in seperate inputs
Posted on Apr 23, 2010
Testimonial: "THANKS,HOWEVER,I HAVE TRIED TO CONNECT THE BOX TOUSING THE RED WHITE AND YELLOW LEADS AND ALTHOUGH THE X BOX SWITCHES ON THERE IS NOTHING ON TV SCREEN"
  • Eddie McGeough Apr 23, 2010
    ok you have to press a/v button on remote or source button.......if your freeview is in through scart it will always default to that
Sharp tv was set up with satelitte- now no signal with freeview box - do i have to reset tv?
Have you changed the input setting on the TV to match up with the input port you have plugged the freeview box into on the back of your TV?
Mar 02, 2015 | Sharp Televison & Video
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like Amazon.com,Ebay.com buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Feb 14, 2010 | Televison & Video
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Acer L5100 and TV Tuner
Try normal arial first.
If OK, try freeview box again.
Check what tuner card you have fitted in Device Manager and check specs on google. Can it receive satellite freeview?
May be new drivers - check Tuner card website for driver updates and latest info.
reply back with what card is fitted.
Aug 08, 2008 | Computers & Internet
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
