Question about RCA P52926 52" Rear Projection Television
RCA model P52927
I'm having to clean the inside of my screen, my son dropped lamp oil and it's on the inside bottom right side of my screen and speakers. Is the model of my tv RCA model P52927 the same as P52926 52 in. as I read how to take off the screen on that model will mine be the same. I'm not turning on the tv until I get that oil off the inside of the screen....
I have a 52 in projection RCA TV with surround system home entertainment that was already plugged in to the wall jack and a internet company decided to put a extra 110 volts in to it. I need to find out how to fix it. Or replace it. I have gotten a estimate and they told me the circuit board is burnt. The internet company insurance said they would replace it but now they want another estimate on the TV and entertainment center. i have already paid 300.00 for 2 estimates, What would this cost to fix, both company's have told me its not worth to fix it would cost more to repair.
Posted on Oct 30, 2008
  • 149 Answers
Let me get some info how to get the screen off and I' get back to you... e-mail me [email protected]
Posted on Apr 04, 2008
2 Suggested Answers
SOURCE:
yambo
  • 230 Answers
SOURCE: RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Posted on May 14, 2008
How do I oil 8 stitch Kenmore sewing machine
Not sure what an "8 stitch" sewing machine is. Model #?
If it's a mechanical machine, the following may be helpful:
Wheel on right side that controls the needle up and down is very tight...
Oct 07, 2017 | Kenmore Sewing Machines
How to oil a singer 457
Every few weeks you should put a drop of oil in the opening of the bobbin case (visible when the bobbin is out) after cleaning that area. (This is to the center front of the bobbin case.)
Every few months, you need to put oil (just a drop) on several points inside the face plate. One spot is high (near the thread take up lever when in its highest position). Then oil the upper shaft of the needle and presser foot mechanism and at the top of the section with the screw midway down the shaft (the farther back). Add a drop of oil at the bottom of the shafts (two spots), Additionally put a drop of oil farther right near the thread path.
Once a year, remove the top cover and place a drop of oil at both holes on the top. (One is near but to the right of the main spool pin; the other is near the thread guide at the take up lever.) Put a drop of oil at the hole at the center right of the deck of the sewing machine (right next to the motor and below the stitch width selector). With the top cover off, there are a number of spots that need oil. One is near the center of the machine at the take up lever (top of shaft). The next is at the center of the stitch width cam. Place another drop of oil at the top of the lever that rests against this cam. Place a drop of oil at the bottom of the lower gear (the one that turns in the horizontal plane). Also oil three points to the right of the vertical gear. (These are the two sections on the shaft to the right of the gear and the point in that same line just to the right of the screw to the back of the area.) Remove the bottom of the sewing machine and oil seven points (three to the left and 4 on the right). Do this carefully - you do not want to get oil on the motor or the belt. These points are on the left: on the shafts near screws at the top and bottom and one spot near the center just in front of the belt. For the points near the screws, the one further up is closer to the left edge of the nachine. On the right side: two points above the belt. One is right next to the belt and one is on the shaft below a screw (this shaft continues to the lowest oiling point on the left side).
The manual for the Singer 457 is available from Singer as a PDF: http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf . See the diagrams starting on page 53 (page 55 of the pdf) for the exact oiling points. I tried to explain these spots but I usually grab the manual for the pictures for my machine for the yearly oiling. You can buy a copy of the manual from Singer for $15 here: http://www.singerco.com/accessories/instruction-manuals/ . Enter the model number without any extra letters at the end of the model number. Then click Search.
I hope this helps.
Oct 06, 2011 | Singer Quantum XL-5000 Computerized Sewing...
I HAVE SONY WEGA 60". lamp light in frot blinks and TV went dark.I presume I need to replace lamp.Can anyone tell me how to do it?
Model number indicated is a 42 inch, not a 60 inch but lamp should be same for both.
The entire bezel (plate of plastic) under the screen has to be removed; you should find on the back on either side a black plastic thumb wheel that can be backed out (it will not come out but just back out until free).
With the 2 completely loose grasp the plate from the bottom right and pull on it from right to left; it is held in with several plastic pegs and will resist being removed; pull from the bottom as it is also secured at the top with large tabs that engage just under the screen.
The idea is to get it free all the way across the bottom and then lift up on the plate and pull it down and away.
Have the set off and unplugged at this point.
The lamp door will be easy to see and is marked. Usually just one screw and with the set off/unplugged the lamp cartridge is secured with 2 Allen bolts (replacement lamps come with a tool).
The lamp assembly has a handle and with the two bolts backed loose you grasp the built in handle and slide the lamp cartridge out and away.
Average life on the lamp is 2,000 hours.
There are two ways to buy the lamp----Google the model number and use the word lamp after it.
Some sites sell a generic "bulb"; you have to dismantle the cartridge and replace the bulb---I do not suggest this as generic lamps do not in most cases have a good record of long life.
Not to mention if you get a cartridge unit you just have to install it and lock the bolts back.
It is very important when you install it you do not touch the face of the lamp with your hand as oil on you hand can damage the lamp.
Also, it is important the two pin plug that connects the lamp inside the set engage perfectly.
These lamps are considered to be "customer replaceable" but you need to do it right.
Please let me know if you have questions as I am here to help you.
Regards, SD TECH
Aug 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have an RCA universial remote control and lost the paper that gives me the codes, i need to reprogram my remote, my TV is an Toshiba "big screen".
Visit this link. On the bottom right side of the page, it is written in red: "Find your remote codes here!", click on this and a new window will open.
Select your remote control model from the drop-down menu and you will be presented with its manual and complete list of available codes.
Sep 23, 2009 | RCA Universal Remote Control
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
P52927 focus and screen module
We are available for conference Today and Everyday. We will assist you in repairing your set. The Part you need is 240623. Please join in conference for part price and location
LOGIN
Circuitcity
Jan 06, 2009 | RCA P52960 52" Rear Projection Television
RCA model P52927
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
187 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
