Question about Konica Revio KD-420Z Digital Camera
Konica revio KD-420Z Digital camera the lens is stuck in the out position how do I fix this
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
Testimonial: "a lot of use-full ideas thanks for them "
  • catchjudo Aug 14, 2010
    thanks for your help and advice it was very good however it did not solve the problem this time,
System Error
The systems control board has malfunctioned or it has detected a problem with the camera, this will require a camera technician, but honestly you are better off putting your money into a new one.
May 15, 2012 | Konica Revio KD-420Z Digital Camera
Do you have manual for konica revio KD-200z
You can download a manual from
http://www.retrevo.com/support/Konica-Minolta-KD-200z-Digital-Cameras-manual/id/200ci476/t/2/
Let me know if you have any more questions or problems. Please rate this solution. thanks.
Sep 27, 2011 | Konica Revio KD-200Z Digital Camera
Hello i have a KONICA Digital REVIO KD-210Z but my Walgreen Photo SDHC 4 GB Memory Card doesnt work on it. PLEASE HELP
The camera is designed to work with SD cards, not SDHC cards. You need to go with SD cards, 2GB and smaller.
Sep 17, 2010 | Konica Revio KD-210Z Digital Camera
Kd 400z Konica Advocate errors0042 en errors400e
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
Jun 19, 2010 | Konica Revio KD-400Z Digital Camera
My camera lens wont close and says system error s0042 konica revio kd-310z
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nov 08, 2009 | Konica Revio KD-310Z Digital Camera
Usb cord
There are currently four of them on eBay
Feb 14, 2008 | Konica Revio KD-310Z Digital Camera
Konica Revio KD-420Z Digital Camera Logo
145 people viewed this question
Top Konica Cameras Experts
Robert A. Watson
Robert A. Watson
Tony Parsons
Tony Parsons
Are you a Konica Camera Expert? Answer questions, earn points and help others
