Question about Frigidaire Washing Machines
How do i remove the agitater to clean under it
  • 6,784 Answers
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle or something of this nature against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Posted on Apr 23, 2010
4 Suggested Answers
sclarke7
  • 222 Answers
SOURCE: i need to remove the agitater from a 90 series kenmore washing ma
remove the top of the agitator by pulling hard at a 45 degree angle toward yourself, grab the plastic piece you see inside with a pliers and pull it straight out, use a 1/2 inch socket with extension remove the 1/2 inch bolt and lift entire assy straight out.
Posted on Apr 07, 2009
  • 401 Answers
SOURCE: how to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Posted on Jan 29, 2010
  • 37 Answers
SOURCE: To get coins out from under the agitater. I
JimNeal406 --
The impeller has a friction fit after the bolt and washer has been removed. The dis-assembly diagram is available online at:
[http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114870.pdf]
You might get the impeller to release if you thread the bolt back in without completely tightening it and then use a wooden (or hard rubber) mallet to strike the bolt to push down on the hub basket drive assembly. Use a deep socket if you need to get better purchase. DO NOT use a metal hammer. A pulley puller may be needed to be used to remove the impeller. Write back if you need further help. -- SWT
Posted on Aug 22, 2010
Testimonial: "Thank you very much!! I will give it a try."
To get coins out from under the agitater. I removed the bolt, but had no luck in removing the agitater. Any suggestions?
JimNeal406 --
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
After top load washer fills with water you can hear the agitator but the agitator does not move
IF WIRLPOOL AGITATOR DOGS FUNNY A REMOVE CAP OF AGETATER REMOVE CAP INSIDE AGITATER REMOVE 7-16 NUT PULL AGITATER OFF FIRST CHECK TO SEE IF IT SPINS IF IT DOES DOGS IF NOT A DRIVE COUPLER IS YOU PROP ITS INBETWEEN YOUR PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
How to clean the screen under the agitater
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
Fairly new ge washer spitts out grease/oil from under agitater
Remove the agitator and inspect the upper shaft bearing condition by trying to push the shaft in various directions. It should not be possible to observe movement in a good bearing. If the bearing looks good, then replace the rubber seal just under the plastic block on the shaft top. You must be very careful not to damage the shaft where the seal lip rides. If the bearing is loose, the machine must be torn down to remove the shaft from the supporting post.
Aug 15, 2009 | Washing Machines
I need to remove the agitater from a 90 series kenmore washing ma
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Mar 12, 2009 | Kenmore 15864/15862 Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Dirt like pebbles left in the bottom of the washer after the cycle is complete
take the fabric softener cap off just pull. then look down the middle there will be a bolt 10 mm loosen it and pull the agitater
Jul 22, 2008 | Admiral AW22 Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Grandma's nylons wrapped around the bottom of the agitater
now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Oct 24, 2007 | Washing Machines
Washing Machines Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
