Question about Husqvarna Viking 1
Viking 1+--Thread breaks during embroidery
My husband got me a used Viking 1+ from off the internet a few months ago. It sews just great as a standard sewing machine. When embroidering, however, the thread breaks every five or ten stitches or so. One time, it seemed to be embroidering just fine when the needle hit the threshold plate, bent and broke. My husband thinks there is something wrong with the needle tension--when it spools up to "3" or "4" on the tension dial, it is almost impossible to pull the thread through the tension disk. It's not real easy to pull through on "0," for that matter. The tension dial moves back and forth automatically while embroidering, otherwise this would probably not be a big deal. I did not notice this problem when we first received the machine, but now it seems to be getting worse. I've already tried several types of needles and sizes of thread. Is this a tension problem? It this an easy adjustment fix? Thanks for your help.
  • LauriesMom Jun 08, 2008
    My Designer SE thread breaks when I embroidery. It has been repaired twice and now it is worse than ever. The needles are breaking. A new jump stitch was added to the machine when it was serviced last time. I bought the machine for enjoyment in March of 2007 but it sure is a pain.
    I have changed thread manufacturers and slowed the speed. Nothing seems to help.
  • Anonymous Mar 24, 2014
    Brother BES 1240 Embroidery 4Head machine. I have changed the needle, rethreaded, adjusted bobbing tension and changed thread and sprayed silicone on new thread dk what to do this is frustrating
  • 106 Answers
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Posted on Mar 26, 2008
Husqvarna H class600
Take an example of the problem to a Viking store and talk with someone knowledgeable about embroidery. Generally, a "birds nest" under the fabric relates to improper upper thread tension but the additional variables of type of thread, type of fabric, type of backing, and needle size and type can all play a part.
Jan 03, 2013 | Husqvarna Viking 1
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
When I sew with the regular portion of my Designer One, all is fine. I've been using the embroidery attachment and when I embroidery a simple design, the top looks great, but the bobbin thread is sooo taut...
The bobbin tension sounds ok if regular sewing is ok. The upper tension unit may be the culprit in that there are loose threads or fluff causing the discs not to tighten enough for embroidery. The best solution is to have it serviced by an authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Oct 30, 2009 | Husqvarna Designer I
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Viking scandinavia 400 everything goes to zero
To answer exactly, I need more information.
Is anything flashing in the main screen? The foot? the spool?
Mar 10, 2009 | Husqvarna Viking 1
Embroidery Hoop
Any authorized Husqvarna Viking dealer will be able to get the hoop for you. Replacing the screw is much more economical and that same dealer will have access to the part number so that they can order it for you. This will take longer but will cost about 1/10 as much.
To find your nearest dealer, or one a little farther away, check the dealer locator at:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Aug 27, 2008 | Husqvarna Viking 1
Thread get's tangled and attached to plate while embroidering
Just a thought. Is it possible that your thread is wrapping around your spool post or snagging on your thread spool?
sewman7
Jun 09, 2008 | Bernina Artista 180
Sewing Machines Logo
206 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
