Question about Nikon Coolpix S210 Digital Camera
Camera is telling me lens error
The camera opens then recoils and stops and gives me a lens error
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
Lens error restart camera
Most digital cameras, with zoom lenses, will generate an error, when the lens can't move freely. If you manually stop it, it will give the same error. The camera will retract the lens and generate an error. But if a mechanical error causes the lens not to operate as it should, you get the same error. The camera stops to prevent greater damage. If you can see anything that obstructs the movement of the lens, try to remove it. If you can't see anything, you have to fear something inside the camera is defect and only can be repaired by a technician. Just consider if it is worth paying for a repair, when new camera's are becoming cheaper by the day.
Jan 18, 2014 | Canon IXUS 80 IS Digital Camera
Lens Error
As a camera repairman, I can tell you that even replacing parts, you will never get all the sand out and it will most likely continue to give you problems.Sell it for parts on ebay and buy a working one.
Aug 29, 2009 | Nikon Coolpix S210 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Two cameras and two lens erros
I don't think either camera is worth the over $100.00 that it will cost to fix. However, look at my posts on this problem of lens errors. By forcing gently the lens in or out when you start the camera and shut it off, it may get the lens to work again.
This may damage the camera even further, up to you, and may be worth a try.
Apr 11, 2008 | Nikon COOLPIX L3 Digital Camera
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Help with my camera
stop asking! give some answers!
Mar 22, 2008 | Fuji FinePix A345 Digital Camera
CAMERA GIVES AN "SYSTEM ERROR S0041" MESSAGE
I have this error too, except for me, the lens won't go back in, so I can't close the camera.
Feb 25, 2008 | Konica Revio KD-500Z Digital Camera
Dropped camera-lens stays open
The only way to fix a lens error is to send into casio and have it fixed. Call them at 800-706-2534 option 2 and tell them you have a lens error. They will tell u how to go about sending it in for repair.
Nov 25, 2007 | Casio Exilim EX-S600 Digital Camera
Sanyo camera
then stop opening it..... oh i couldnt help that. system errors means something obviously is wrong and beside electronics many focus and lens errors...but in real terms system errors sound more like electronics,example the ccd or micro or lcd..etc. good luck
Sep 01, 2007 | Samsung Digimax S500 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
