Question about SanDisk Sansa m250 MP3 Player
Unplugged the mp3 player from the computer and now there is only a white screen
  • 15 Answers
I did the same thing. Slide the power switch to the ON position all the way and hold it there for at least fifteen seconds before releasing it. It then turns off. Allow 5 seconds and turn on as ususal. This might not be your problem, but worth a try...
Posted on Jul 26, 2010
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa mp3 player screen turns white
May be hardware, but:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: i unpluged my mp3 from the computer and the screen went white
you have to turn it off before you do that just to let you know
Posted on Aug 04, 2009
YourZEN
  • 820 Answers
SOURCE: blank white screen
Did you try gently pushing the tiny RESET, with a narrow pointed object like a paperclip on the back side ?
01a0fc5.jpg RESET pin hole back side ( 8 ) .
Manual for the MP610 in pdf format:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
Posted on Jun 01, 2010
SOURCE: Mp3 player keeps saying "no files" when i unplug
I had the same problem. I formatted it to FAT format and it started working again. It has to be FAT. FAT 32 and EXFAT don't work.
Posted on Sep 18, 2011
Blank white screen
Jun 01, 2010 | Coby MP-610 MP3 Player
After I charge my sandisk sansa fuse mp3 player i unplug it from my pc and the screen goes completley white and it will not do anything. It will not even turn off after this
I went to the sandisk website and downloaded a firmware software to my computer and then downloaded it to my mp3 player. After that it updated the information and it worked again
Jan 03, 2010 | SanDisk Sansa Fuse MP3 Player
Coby MP815 white screen of death
unplug the lcd cable and plug it again. it will work if the lcd is ok
Dec 05, 2009 | Coby MP815 Digital Media Player
I unpluged my mp3 from the computer and the screen went white
Aug 04, 2009 | SanDisk Sansa m230 MP3 Player
The screen is just white
try pluging and unplugging it ( safely ) from the computer. it happened to me often. be careful because u can burn it by unpluging it from the computer unsafely
Jun 29, 2009 | Apple iPod nano
My Sansa E260's screen is white and it won't turn off
you have to hold down the power button for 13 whole seconds. I have had the same thing happen to mine and I dont know if there is a permanent way of fixing it but that should turn it off so you can turn it on again.
Apr 13, 2008 | SanDisk Sansa e260 MP3 Player
Bright White Screen
just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
