Question about Kenmore 24032\24036 Top Load Washer
Water-level switch shorting out
Kenmore 90 series washer
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
It has a section on testing components including the water level switch:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to release the console and cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Posted on Apr 23, 2010
How to fix a Kenmore 90 Series when the water keeps running?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this will help you to fix your washer,
Gene
Aug 09, 2011 | Kenmore 22422 Top Load Washer
We have a Kenmore 90 Series washer and the water level function has stopped working and the water does not shut off - it just keeping running - therefore the wash cycle does not begin b/c it just keeps...
The ppart you are looking for is called the water presure switch and it is located inside the control panel.It will have a small plastic hose going to it. Hope this helped.
Jun 03, 2011 | Kenmore Washing Machines
Washer keeps filling up with hot water
Hi
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Washing Machines
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series heavy duty washer
If it fills up to normal level on other settings then the water selector switch is bad.
Look at the back side of this switch and you should see a tube connected from the switch to the lower part of the tub. Take the tube loose at the switch and blow through to check for any blockage. Look at the tube for holes.
Nov 14, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
91 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
