Question about Fujitsu Siemens AMILO Pro V2010 Notebook
How do I switch on the wireless card? - Fujitsu Siemens AMILO Pro V2010 Notebook
    Problem Solver:
  • 18 Answers
Press FN than F1 or F2
Posted on Apr 23, 2010
No wireless
Hi
If there is no wireless and there is a wireless network card built into the PC then, the following will be issue
1. The card has been switched off by the switch either on the case or keyboard, consult the manual for the actual location and switch back on
2. There is an issue with the wireless drivers reinstall them from the install disks, you may have to make these from included progam if you have not done so already.
3 The card has been disabled in BIOS go to BIOS and re-enable
4. The card component of the main board had become faulty go and buy a replacement USB wireless card.
Cliff Cook
MCP
Jun 19, 2014 | Acer AM3900-U4002 Desktop Computer
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Can't access wireless card
Why not? Is the wireless card inside the laptop? Have you turned the wireless switch on? The wireless switch is located on the side or in the front of the laptop.
May 02, 2012 | Computers & Internet
Unable to detect wireless card
Did you install the drivers for the Broadcom Wireless Card? If you did and it's not showing up the card is bad.
Mar 25, 2012 | Computers & Internet
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
Dec 20, 2010 | Computers & Internet
How to switch to wireless
To Switch over your pc to wireless??You should have wireless cared.
Sep 17, 2010 | Computers & Internet
After i format my lenovo computer i found that everything is ok except for my wireless and bluetooth problem though all the drivers needed are installed. Then i try to take out the wireless card underneath...
Hi. Make sure that all drivers are installed and the wireless card switch is turn on. Try Disabling/Enabling the wireless card by pressing the Fn + F5 key.
Jul 11, 2010 | Lenovo (40Y7026) Wireless Adapter
How is wireless capability switched on my laptop
Check the BIOS setting - the wireless card needs to be enabled.
Next check Control Panel - Device Manager - Network Connections. The wireless card it should be enabled and working. If it has a yellow ? against the wireless card then the wireless card driver needs to be installed.
For details on configuring and securing a wireless router and configuring the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | Belkin Computers & Internet
IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Oct 07, 2009 | IBM ThinkPad R30 2656 Notebook
How do you switch on the wireless card?
Hi! If you are using a laptop, the wireless switch of the laptop is either on the sides or you need it to turn on at the bios setup page, If you are using a wireless card for a desktop computer, all u need to do is to install the driver for the wireless card in order to work with ur operating system..
Aug 09, 2009 | Computers & Internet
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
200 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
