Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Xerox xd125f Hi, the copier is squeaking and the print is coming out with smudges. Is there a way to lubricate it? The fuser gear turns real hard. The squeaking is coming from that end. If it is something that needs to be replaced or lubricated, please send instructions or point me to a website that has them. appreciate an email to timothee400@yahoo.com
    President:
  • 2,072 Answers
Most likely you need to replace the fuser assembly itself.
You can order it piece by piece, but you would have the cost of a heat roller, perssure roller, thermistor, gear and bushings. And that prices out more then a new fuser itself.
They can be purchased for the 200-230 dollar range.
If thats the route you want to take let me know. I can write out the instructions for replacement. It's not to hard to do.
Posted on Mar 25, 2008
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Xerox Phaser 4510 - While printing it makes a squeaking noise
One of two things. The fuser bearings get noisy in those.
Or there are several small hard plastic rollers on steel shafts or even mounted on springs they they can get very noisy.
Feb 24, 2010 | Xerox Phaser 4500/YDX Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Workcentre XD125F
Waste ink reservoir is probably full. Needs to be emptied.
Hope this helps. Bud
Jan 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Printing to Xerox XD125F
That will print via Parallel port , Just have to go to www.xerox.com
go to drivers and downloads and then type in xd125, dowoload the driver and use the autosetup.
It is easy to set up.
Apr 12, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox XD125F
What you can try is just replacing the fuser drive gear and the bushings on the heat roller.
That small tube your relating to is the heat roller. The plastic like busings are really tight not allowing it to move freely.
Not the easiest fuser to rebuild to be honest. You will also want some high temperature lubricant to use on those bushings and also on the pressure roll shaft to make that roller run smoother.
Clean it well and be sure it is running free.
You need to look at the heat roll and presure roller carefully to check for wear and grooves. If they are worn, you will be better off replacing the fuser then trying to rebuild it.
I will provide you the link to an excellent parts source, click on parts then the scroll down tot the XD125, They have about everything you want for that fuser.
If you call ask for Britt..
https://www.partsdrop.com/store/
Apr 08, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Paper path jams...
The most likely problem in that is a bad fuser roller gear.
Most likely there are a couple of teeth broken off the gear.
You have to remove the back cover, which also requires the removal of 2 screws on the top of the machine.
REMOVE THE POWER FIRST.
Then there are two plugs to remove, looking on the back they are lower left. 2 white connectors
Open the right side drawer, remove 2 silver screws holding in the fuser. It will say Caution Heated Surfaces. one silver screw on each side.
Pull it straight back, slowly and examine the gear on the right side of the fuser.
You may just fine an accordion folded piece of paper in there under one of the fingers. But that gear is prone to breaking teeth off.
Dec 29, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Printer problen
Low Fuser Temperature. Probably a blown heat lamp try reseting the H code Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code comes back. Tim
Jan 28, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
163 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
