Question about Dometic 57915531 Air Conditioner
Blower motor won't start
On my Dometic model 57915.531
Air Conditionned, blower motor won't start
    Habit-Forming:
  • 193 Answers
May be a dead start cap
Posted on Apr 24, 2010
Dometic roof ac mod SL135RB. Blower motor works fine. No cool air comes out
compressor not running. capacitors, thermostat, relay board all possible.
Oct 28, 2013 | Dometic Rooftop RV Air Conditioner
How do I replace a blower motor on a model 57915331 dometic air conditioner
First , shut of breaker to the unit. Are you sure the motor is no good? What symptoms did you have when trying to start on just fan setting?
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
My blower motor comes on but will not turn fan.
May be error code e-4. It's problem with blower motor mechanism fault. Replace if bearings worn out. or replace blower motor.
Dec 15, 2010 | Dometic Rooftop RV Air Conditioner
Dometic 579 Series Brisk Air AC runs fine-blower still runs but every couple minutes it "kicks on and off" it will blow hot air and then cold air and continues to do this. Did not do this until we...
sounds like it is skipping the motor I mean, I am assuming that it was replaced with the correct motor(rpms,hp,volts). As if it was not it will skip, like it is doing now.
Aug 28, 2010 | Dometic Rooftop RV Air Conditioner
I have a FEMA camper and my rooftop A/C makes a humming sound with no air flow. what do you think ?
Hi!!
It seems like the blower motorr is not kicking in. Turn breaker OFF, remove the grill, check that electrical connections are nice and tight, and turn breaker back ON, start unit and see if evaporator coil is gatting cold, if so, Turn Breaker off, remove blower motor capacitor and test it, if capacitor OK, blower motor needs to be replaced.
Good Luck!! Rate this Post!!
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic 579 Series Brisk Air AC. The model Number is 57915.531. When I turn the fan on, nothing happens. If I reach up and turn the wheel blower the fan will start up and everything works. I...
My sheet shows part # 3100248.420 as fan run capacitor.You may have an updated number. Check voltage outputs labeled on it are same as on old one, and double check wiring is correct, to and from capacitor. Be careful not to mistake compressor start capacitor as well. By sounds of number, it's probably the right one.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
How do I install a blower motor in a duo therm model 57915.622? What tools will I need?
ITS NOT EASY. YOU NEED A LONG SET OF ALLENS TO LOOSEN BLOWER WHEELS. THIS IS A  DUEL SHAFT MOTOR , BACK COIL NEEDS TO BE PULLED AWAY FROM MOUNT WITHOUT BENDING COPPER. MOTOR BOLTS 3 OF THEM HAVE TO BE REMOVED AND WHEN BOTH BLOWERS ARE REMOVED AND WIRES REMOVED THEN IT CAN BE REMOVED . THE PROBLEM IS THAT THE NEW MOTOR IF IT IS NOT FROM DUO THERM YOU WILL HAVE TO CUT SHAFT TO RIGHT SIZE AND WIRES MAY NOT BE SAME COLOR. IF IT IS SAME MOTOR FROM DUO THERM YOU CAN CUT WIRES AT OLD MOTOR AND WIRE NUT THEM COLOR BY COLOR.
Apr 19, 2010 | Dometic Rooftop RV Air Conditioner
Dometic 57915531 Air Conditioner Logo
280 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
