Question about Saeco Incanto Classic Espresso Machine
Very little steam or unconstant steam
The coffee works well and the taste is good but when I try to heat my milk with the steam nozzle, not enough steam comes out of it and it seems to quit like if there is not enough pressure on the steam.
thank you
I tried the obvious by cleaning parts and descaling and probing a wire in through the steam valve.. I ended up trying to get an expert on it from the area, he evaluated it and said that it was not worth working on that it would cost over the price of the machine.. I found another person who worked on it as a worker on appliances,.. after taking it apart he found the problem was the first premise that the steam valve metal pipe inside was badly clogged with lime, so he cleaned it out and got it working fine. Now the problem is replacing the parts that seal the machine from someone doing what they did by opening it up.
Posted on Apr 28, 2010
The steam milk facility in my CVA5060 is not working; the machine tells me to 'clean milk pipework' . It looks from the manual like I should have a specific flask for this; I don't have one. I...
You have clogged milk pipework, likely caused by not rinsing/cleaning the pipework after dispensing milk. This has happened to me a few times and we have had Miele out to fix it. Only they can unscrew the unit to look inside and repair can be expensive. Today, I found a solution I wanted to share!
Remove the front cover off the spigots so you can clearly see the nozzles where the milk runs out. Run a rinsing program on the unit, and it will emit steam and hiss and nothing will come through. That is OK for now. Using a balled up towel, plug the side where you are only getting steam coming through. You are essentially causing pressure to build up in the pipework which will dislodge whatever is blocking the system. Careful, as steam will penetrate the towel as my little burnt finger will tell you. The second time I did it, I pressed the towel into position with a spoon....works like a charm and no burnt fingers. Both sides were blocked for me and now run smoothly. Hope this helps someone ;)
Sep 16, 2011 | Miele Coffee System
Coffee comes out tasting acidy and plastic. Not even close to being flavorful....it's a new machine and I've followed instructions. Back to my bodum? or can someone help?
run about 3 half pots of vinger and water 50/50 through it. then 2 with clean water.
last thing if that don't work is run 25% simplegreen 75% water then 2 pots of fresh water.
after that call the coffee maker mfg.
Dec 29, 2010 | Keurig Platinum B70 Coffee Maker
Not enough steam is produced to make good froth.
I have one too and what I do is: turn all 3 switches on and while I'm waiting for the "ready" light to come on I go ahead and pour the milk into my frothing pitcher and prep my espresso basket.
After the "ready" light comes on I install my espresso basket and turn the handle to the "left" so no liquid starts coming out.
Next, I take an empty coffee cup and hold it under the steam nozzle and start opening the steam valve until I get only steam instead of a stream of hot water. Once you have steam, close the valve, put your pitcher of milk under the steamer and froth as usual to around 150 degrees.
Jan 21, 2010 | Coffee Makers & Espresso Machines
Salton Model # 17
I think I've figured my yard sale EX 80 out. First, the way I think it works... in the tightly sealed boiler the water is heated to boiling, it must have a pressure release valve that sends the water/steam through the coffee and into the carafe. So dangerously hot and under pressure. Before opening the big round cap at the top (reservoir) relieve pressure at the steam tube valve (right side)
Here's how I made my first batch:
When opening reservoir always turn unit off, let reservoir cool a little between batches or you may get a cloud of steam in your face when pouring in water, might not be good for the heating element to shock it with sudden drastic temperature changes either.
Cleaned by running a couple of jugs of water through, cold water (4 on the supplied jug) into the reservoir all parts installed. I read somewhere online (not specific to any machine) not lukewarm water, if it's online it must be true... right?
Put coffee into filter basket/basket holder, matching amount of water in reservoir, 2 or 4 (markings on filter and jug). Espresso coffee should be very finely ground
Install all covers and the coffee basket/filter basket, close steam tube valve, install carafe and turn on the machine. Should get blast of espresso after a couple of minutes.
The steam tube (operated by the valve) seems a little cheesy on first try but I'll get better with practice. There's no steam to the tube until the reservoir starts to send steam to the coffee, the coffee kinda restricts the steam enough to send it to the tube. I was thrown a little because I didn't get steam when I was cleaning the thing, but I think that was because there was no coffee to block the flow. So I opened the valve at the start of the brew, steamed the milk, closed the valve and then the steam blasts through the coffee, tasted good.
Great $1 find.
Hope this helps.
Apr 27, 2008 | Salton EX80 Espresso Machine
Steam nozzle
For the coffee - make sure the machine has heated up for at least 10 minutes. I've found the grind is the most important in getting a good shot of espresso with a good crema.
It takes trying different grinds to find what works best. When we grind at the store we choose the second finest grind from the finest - we put it to Turkish and then turn it back one notch.
On the steaming side - it takes practice. Sometimes I get froth, sometimes - I usually let the wand go near the bottom of the steaming cup and heat the milk to 160 deg. f.
Apr 06, 2008 | Rancilio Silvia Espresso Machine
Coffee tastes burnt/No steam for froth
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Feb 26, 2008 | Mr. Coffee ECM10
Steam jet in Saeco Classico
Try Descaling your machine. A lot of times calcium will form on the inside of the boilers and on the heating elements in espresso machines causing heat transfer issue and clogged lines.
If the heating element cannot transfer enough heat fast enough then your steam will run out.
If you need a good descaler or descaling instruction visit www.CeriniCoffee.com
Dec 22, 2007 | Saeco Classico Espresso Machine
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Wet Steam? Weak Espressos
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Sep 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Incanto Classic Espresso Machine Logo
422 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
