Question about Jura Capresso Jura / Capresso IMPRESSA S7 Avantgarde Espresso Machine & Coffee Maker
Schale fehlt--not sure what this means, or what to do.
Cyberhome SP05A speaker system
Hallo ich hoffe ich bekomme eine Antwort. SO ich habe die CyberHome speaker system 5.1 ch und habe alles angeschlossen, nur mir fehlt das DC 12v 50w kabel von der Box wo man den Bass/Volumen/EIN und Aus regeln kann und nu meine frage BRAUCH ich das und wenn ja wo kann ich sowas nachkaufen? ich habe schon gegoogelt (dc 12v 50w) und habe nichs gefunden. jetzt habe ich zuhause noch 2x DC Stecker gefunden DC 12v 700mA und DC 12v 1A aber die passen nicht rein. und nu will ich nichs kaufen wenn ich nicht genau wei? ob es passt. Linkt zu kaufseiten w?hren auch gut. ^^
danke schonmal im Vorraus.
mfg ICH :P
Sep 02, 2013 | Cyberhome Area SP05A Speaker
94 grand cherokee baterry goes dead after sitting 5 days starter clicks and flashers flash. recharged battery will last another 5 days,
battery could be at fault or there is a draw in system that pulls down battery
have battery tested and leave it disconected for a few days then reconect to see if vehicle starts
if it does battery should be o.k. next is there any thing that stayes on (aftermarket stuff)
that may cause a draw on system if thats ok need to performed parasetic draw on system
hook up voltage meter between positive cable and meter
on 20 volt schale put red wire of meter to battery positive post black wire to red wire that was hook to battery voltaged should be minimal only to keep computers alive (clock - radio preset-etc etc)
if draw is high start removing fuses in system one at a time and check the voltage meter until it drops
you have now located the faulty cicuit that that fuse feeds start looking in those area
also feel starter selenoid and alternator at rear to see if they feel warm thet could be partly switch on
killing the battery over time
good luck
Apr 01, 2011 | 1994 Jeep Grand Cherokee
Not showed f2 f8 f12 and say bootmgr fehlt
You have hard drive errors or system file errors.
Sounds like it's too late to try and restore your system.
Place your OS system disc in your drive and boot from it setting up a fresh system on your hard drive.
Jan 08, 2011 | Computers & Internet
We have lime schale build up
Ace Hardware carries a product called "Lime Out". You may find the product in other fine stores as well.
Treat your machine per container instructions.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Dishwashers
Conrac Plasma Display 4042
Found cold soldering point on tuner board.
Sep 11, 2008 | Fujitsu Plasmavision PDS-4203 42 in....
P5WD2-E Premium
Intel Socket 775 Pentium® 4/Celeron Processors
Compatible with Intel® 05B/05A/06 processors
Intel® Hyper-Threading Technology ready
Support Intel next generation 65nm CPU
This link will show which processors are compatible( look for the 65 nm Manufacture tech.) Filter on
  1. Package type LGA 775
  2. Bus Speed 1066
  3. PCG 06
Looks likeno quad just Duo
Mar 22, 2008 | ASUS P5WD2 Premium Motherboard
MSI K8TNeo2-F v2.0
This is not too uncommon scorcher63.
From what you stated, when windows does start it only goes so far & than re-starts it's self, like loading in a loop. Than at times it loads the start up options.
For reasons unknown, your windows (startup files) are corrupted. Easyest way to fix this is. Put you windows CD in the cdrom, shut down the system. Start the PC & press the F8 key every 2 seconds. A boot menue will load. Use the up & down arror keys & choose the cdrom drive. You will see (to boot from cd press any key), press the space bar. The cdrom will startup. Windows will start to load. You want to repair windows. This option will re-install windows but will leave most of your personal data alone. Like My Documents your username. Some programs "may" need to be re-installed. After installation is complete remove the windows cd & shut off the PC. Start the Pc, windows should load. Run Windows Update. If you have a antivirus program please do a full system scan. Run windows Defrag program.
scorcher63, if you have more question just post them here.
Feb 21, 2008 | MSI K8T Neo2-F Motherboard
Jura Capresso Jura / Capresso IMPRESSA S7 Avantgarde Espresso Machine & Coffee Maker Logo
175 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
