Question about Whirlpool WED5800S Electric Dryer
When tub turns it makes a thumping noise - Whirlpool WED5800S Electric Dryer
  • 27 Answers
Check the drum rollers. this isn't a hard fix the rear rollers usually come 2 to a pack are around 15-30 dollars
Posted on Apr 23, 2010
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Tub thumps after nail wedges through small hole bottom and stops tub
You could have an unbalanced tub or the piece is rotating around in the outer tub and making the noise. Contact a professional to have the machine taken apart if the noise continues.
Jul 28, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer tub makes noise as it turns. 2000 model kitchenaid clothes dryer. noise occurs while drying. thumping sound.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 01, 2011 | KitchenAid Dryers
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Whirlpool LSN8244AW0 began making a loud thumping noise which quickly got worse then turned machine off; appears that tub is off balance and hitting all four of the inside walls during spin cycle. Do i...
The problem might be springs of the unit might be loosen or the suspension which holds the washing machine drum unit kindly replace the after checking which is faulty.It is difficult to find in spring but in suspension it must not go freely if if goes freely means kindly replace the suspension this problem will be solved
May 15, 2010 | Washing Machines
Bosch WTMC3500UC Gas Dryer Dryer...as it is turning makes LOUD clanging banging noise. Will make the noise when turned by hand does not make the noise when tuned by hand in the other direction.
heatman101
gkjlgkj
Feb 15, 2010 | Bosch WTMC3500UC Gas Dryer
Loud thumping noise during spin.......not related to unbalance....manually turning the tub makes a loud noise.
Bearings shot or counter weights have come loose
Take the top off and check the weights first
Jan 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Whirlpool WED5800S Electric Dryer Logo
91 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
