Question about Brother MFC-8840D All-In-One Laser Printer
Okay so my brother mfc8840d isint working. whenever i hit a button it makes a beep noice three times then doesnt do anything. its almost like it just died.... whats wrong with it? i need to make copies!
    New Friend:
This does not work for me I have tried everything I really need help to fax. I can print to printer from computer but every key pressed on printer beeps three times.
Posted on May 16, 2013
    President:
  • 405 Answers
The beep noise three times indicates taht there is an error or one of the buttons are stuck.
Please turn off the Brother and press down on each button.
Posted on Apr 23, 2010
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Oct 09, 2013 | EDENPURE USA1000 Infrared Heater
I have a dial tone, the operator can speak to me, but I can not dial. I get a three beep noise. The function key and all keys just make a three beep noise. The only keys that do not give the three beeps...
see this pdf file this will guide u sir.............
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Jul 17, 2008 | Brother Office Equipment & Supplies
Xbox 360 slim wont turn on but it beeps and lights up
there is a short somewere In the system and it is in protect mode and will not turn on so that the console does not get harmed anymore than it already is. the best solution for this is to send it in to Microsoft and get this problem fixed
Jul 11, 2013 | Microsoft Xbox 360 Slim Black Console
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
Key pad on brother 1020e fax mc seems to be locked when you press copy for ex it just beeps 3 times
When the Brother machines beep three times while pressing any button on the front panel, this means there is a button stuck. Try pressing all buttons over and over to unstick button. This should help. Please rate my help if this works. If you need anything else, save my user name and ask me anytime. Thanks!
Jan 21, 2009 | Brother FAX-1020e Plain Paper Thermal...
I think i have disabled the remote how do i enable it
you have to hit the star or start button twice...if that doesnt work try hitting the trunk button three times...each press should be a second long and a second inbetween presses...hope that works
Jan 16, 2009 | 450-R Deluxe Remote Starter with Keyless...
Brother MFC-8500
what normally helps with brother is unplugging the machine for about an hour and plug it back in.
In your manual says how you can make a test print.
This will clear your internal buffer.
Also it might help un installing the machiine from your network and installing the software new.
try it and let me know what happens
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Brother MFC-8840D All-In-One Laser Printer Logo
268 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
