Question about Leifheit Soehnle Slim FT5 Digital Bath Scale with BMI Technology
Scale displays overload no matter what I do
I am trying to set up this scale. No matter what I do, it flashes 'overload' (I'm not even standing on it)/ After I set the time, after I program the data for P1 - 'Overload.' Help!
Amazon telephone number
rules of return policy are just that . and no one here can change what amazon policies are . this is not amazon but FIXYA
Mar 06, 2017 | Health & Beauty
The scale displays 8888 every time you stand on it. If you go to choose p1 it flashes data. Can seem to get the scale to reset using the instructions and removing batteries does nothing
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
Jan 05, 2011 | Conair WW81 Weight Watchers Body...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
My scale is now set on pounds. I would lik to change back to Metric
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Apr 08, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
How to utilize the WW87 Glass Body Analysis Scale?
I discovered that it helps if your feet are slightly damp. I usually wipe them with a washcloth before getting on the scale. They don't have to be WET, just every so slightly damp.
Dec 20, 2008 | Conair Weight Watchers WW-87 Body Fat...
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Leifheit Soehnle Slim FT5 Digital Bath Scale with BMI Technology Logo
155 people viewed this question
Top Leifheit Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Leifheit Health and Beauty Expert? Answer questions, earn points and help others
