Question about Alpine TDA-7564
PANEL LIGHTS OUT COMPLETELY. RECEIVER WORKS FINE.
Power supply ok..coz the stanby red light is on?
At least the 5 volt is working. But what does the knowledge about the power supply change?
The Audio & Video receiver (Unknown brand and model) is obvious defect. Without enough electronic knowledge and without skills to repair it, it won't bring you anywhere. Did you check everything is connected as it should be? no shortage on the speaker cabling? No extra on / off switch?
Last Amplifier I got on my desk, was "complete defect". The owner / user, had it at least 5 years and did not notice the on / off switch was in the off position. I pressed the button and it worked fine. That was the first time the owner saw that switch, although the words on/off were printed under the switch.
Jan 22, 2015 | Audio Players & Recorders
Stovetop & Oven not heating but clock, lights, & vent fan are working
It sounds like you are getting only one side of the power to your stove. the lights will work but no heat. your power breaker has two sides for an electric stove. It may be one side isn't reset properly. make sure that you snap the breaker completely off and then completely back on. if that doesn't work perhaps an electrician is in order or one side of your power cord has burned off at the terminal block. I have had this happen.
Apr 28, 2013 | Kitchen Ranges
Hi my mouse has worked for years. I just changed the battery in the mouse and now it will no longer work. The jump drive turns red when I push the mouse up to it then nothing happens. I went to Control...
From your description, it sounds like the wireless connection between the mouse and the USB receiver (jump drive) isn't resetting. Here are the steps to reset the connection after changing batteries:
With the computer on, mouse on, and receiver installed in the USB port...
1. Turn the mouse over and aim the front at the receiver, like this:
thomascha103_8.jpg 2. Press the "connect" button on the bottom of the mouse. It's small and round, next to the power switch.
3. Then press the "connect" button on the receiver
(the connect buttons always have to be pressed in this order)
4. When you press the button on the receiveer, the light will turn on. Keep the mouse pointed directly at the receiver until the linkage is complete and the light turns off.
That whole process has to be completed in under 60 seconds. If it takes longer, you'll have to start over.
At least, that's how it works for me. Here's a link to the user manual with other helpful troubleshooting tips:
http://cache-www.belkin.com/support/dl/f8e825-usb.pdf
Best of luck!
Jan 20, 2011 | Belkin Mini Wireless Optical Mouse...
I purchased a brand new Sony Bravia KDL-32L5000 LCD digital color tv with a remote RM-YD028 which worked fine for about 1 year. Then, the remote completely stopped working. Double checked the...
From your description, I would suspect that the IR receiver inside the TV has failed. If the TV can be controlled from the panel buttions, that adds to that suspicion. Please note that it is possible that the receiver has poor solder connections and that this can be easily fixed. Even with replacing the receiver, the part would cost only around $10 or so. Check with local repair shops for a cost to repair this.
Dan
Aug 25, 2010 | Televison & Video
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Receiver Lights???
this is completely correct. its like a wired keyboard.
Aug 06, 2008 | Microsoft Wireless Laser Desktop 4000...
No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
Nov 16, 2006 | Onkyo TX-SR601 Receiver
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
Help front panel wont work and treble +10 keeps coming up by itself
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Sep 21, 2006 | Yamaha HTR-5650 Receiver
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
