Question about HP OfficeJet 4315 All-In-One InkJet Printer
I have not had a resolution to my problem and am now being ignored?? HELP! Anne
  • 4 more comments
  • anne689 Apr 23, 2010
    again,... do you not have any history??? What exactly is it that I am paying for?????
    again... do you not have ticket history??? What exacftly is it that I am paying for here??
    Anne
    The original history is
    I used to be able to scan fine from my HP4315 but since I reinstalled the software to add an additional printer it won't work
    Comments:
    Apr 23, 2010
    - HI there Thank you! I installed an HP1400. I then got the Photosmart
    Studio which I didn't have before. Trying to do a scan from there
    brings up HP Scan Pro followed by a message saying the scanner can't be
    found. Basically it isn't finding a default scanner at all. I have
    tried resetting everything unplugging everything and reinstalling the
    drivers... nothing.
    Previously I only had HP Scan Pro and would be more than happy to go
    back to that and then elect which scanner I want to use.. Or is that
    eutopia?!
    I should also mention that I run a MAC using OS 10.5.8
    Thanks for your help
    Anne
    Apr 23, 2010
    HI there
    Thank
    you! I installed an HP1400. I then got the Photosmart Studio which I
    didn't have before. Trying to do a scan from there brings up HP Scan
    Pro followed by a message saying the scanner can't be found. Basically
    it isn't finding a default scanner at all. I have tried resetting
    everything unplugging everything and reinstalling the drivers...
    nothing.
    than happy to go back to that and then elect which scanner I want to
    use.. Or is that eutopia?!
    Anne
    Apr 23, 2010
    I would if I could...I don't get that option.
    Do you have a clever way for me to do that?
    Apr 23, 2010
    I did say I am running a MAC and this seems to refer to windows???
    Anne
    Apr 23, 2010
    Also I can print from it just not use it as a scanner..
    Your service will only work if you actually respond to my query and don't assume things
    Anne
    See less
    function setMoreVisibility(val) {
    if (val) {
    $('ctl00_MainColumn_ctrl_question_divMessage').style.display = 'none';
    $('ctl00_MainColumn_ctrl_question_divMessageMore').style.display = '';
    else {
    $('ctl00_MainColumn_ctrl_question_divMessage').style.display = '';
    $('ctl00_MainColumn_ctrl_question_divMessageMore').style.display = 'none';
    Solution #1
    posted on
    Apr 23, 2010
    e-ware
    Rank:
    Guru
    Expert
    Rating:
    85.91%
    137
    votes
    hi,
    Just want to check have you checked the printer settings for your
    HP4315. Whenever you try and scan what is the default printer that is
    set on the computer.
    Also please mention which addidtional printer have you installed and are all they installed on the same computer.
    Please check for the printer sttings as which is the default printer
    added on your computer, you might have to choose manually to use which
    pinter for use.
    Waiting for a response.
    Comments:
    Apr 23, 2010
    Going forward just manually slect the printer that you want to use in the printer setting.
    Apr 23, 2010
    Please click on:
    Start>Control Panel>Printer and Faxes
    Here you should find your printer, over there select your printer and
    do a right click to use it for printing at that time or set a default
    printer.
    Also when you print a documet, befor the computer sends the data for
    print your computer will ask you to choose the printer you want to use
    at that time.
    I copied the entire ticket history for you.. here it is again
    Comments:
    Apr 23, 2010
    drivers... nothing.
    eutopia?!
    Anne
    Apr 23, 2010
    HI there
    Thank
    nothing.
    Anne
    Apr 23, 2010
    Apr 23, 2010
    Anne
    Apr 23, 2010
    Anne
    See less
    if (val) {
    else {
    Solution #1
    posted on
    Apr 23, 2010
    e-ware
    Rank:
    Guru
    Expert
    Rating:
    85.91%
    137
    votes
    hi,
    pinter for use.
    Comments:
    Apr 23, 2010
    Apr 23, 2010
    Please click on:
    printer.
    at that time.
    No as per my copied ticket I run MAC OS X 10.5.8
    So basically I need to rebuild my entire system for one lousy print driver
    ... I don't think so
    I am sorry but your advice and that of your colleagues has been no help at all.
    Please cancel my membership and refund any payment.
    I am very disappointed
    Anne
    It hasnt solved my problem and there is no need to be so rude
    Please close my account and refund any payment. I will report any charges as unauthorised
  • 787 Answers
Please describe your problem.
Posted on Apr 23, 2010
  • 2 more comments
  • Tudor Valean
    Tudor Valean Apr 23, 2010
    This is a community of freelancing experts. This means we are not FixYa employees, so we don't have certain privilegies like viewing system logs and other history than our own.
    So, I can help you with your problem, but you are going to have to describe it to me.
  • Tudor Valean
    Do you, by any chance, run Mac OS 10.6 (Snow Leopard)?
  • Tudor Valean
    OK ... now, this is a known issue among HP printers when running on Macs. Basically, when you installed the second device (4100) you updated the drivers on your first device. And that's when hell broke loose. It took over 6 months for HP to fix this problem (with bad driver updates) and they solved it by recommending a Mac OS X 10.6 upgrade (that one has all the drivers preinstalled). So, there are two possible solutions for you:
    1) Do a complete system reinstall (OS, printers) and disable/block all HP driver updates. Also, don't use downloaded drivers, use the discs that came with the printer(s).
    2) Upgrade to Mac OS X 10.6
  • Tudor Valean
    OK ... read this:
    Mac OS - based systems are very different from Windows ones. They are built to "use", so that you won't have to worry about what's under the hood. Ever. And Apple thought that automatically installing updates is the best thing to do. And it clearly not in HP printers' case. The thing is that you would have to be very computer-savvy to fix this problem without reinstalling the whole system, but if you were, why would you even post this problem here?
    Also, don't hold us responsible for other companies' failure to deliver the best possible solutions to their customers ... it's their problem, not ours.
    We did what you asked us to do: tell you what to do.
I need some links to extend my Anne Klein watch ( I'm become fat now ) Can you please to help me how to order links
Yes, I can help you. Contact this company -
Tulper & Company
2223 E. Colfax Ave.
Denver, CO 80206
You can order it from them.
May 11, 2017 | Anne Klein Watches
How to adjust Time and Date on Anne Klein 10/7899 6P05 Ladies Watch
You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
Nordstrom provides a generic Anne Klein manual here:
http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/anne-klein/anne-klein.pdf
Mar 20, 2016 | Anne Klein Watches
How do I set the date on an Anne Klein watch with only a stem?????
-GB&q=anne+klein+watches+how+to+ http://i.nordstromimage.com/images/.../watch-manuals/anne-klein/anne-klein.pdf .
Hello, you can download a pdf instruction sheet at the above site. Hope it helps. Bye.......
Mar 10, 2015 | Anne Klein Watches
How do I change the display resolution on the control panel ABOVE the maxed out resolution shown so I can use a 17' screen which requires 1280x10xx? When I try to use any 17" monitor, a message comes...
On a 17ins monitor the best resolution is 1024x768 regardless of whether it tells you a different "recommended" display resolution.
Just ignore any warning it gives you and it should work very well with the resolution i've told you, just use the slider to select the 1024x768.
Regards.
Dec 09, 2010 | Acer Aspire AX3300U1322 Athlon II X4...
Replacement clasp for Anne Klein watch, caseback #12/6130-1
mcdevito75 here, Your in a spot with your Ann Klien watch. BEST BET, shop ebay and match up another Ann Klien just like yours and use for parts. On ebay Click in search, watches then Ann Klien.
Jul 26, 2010 | Anne Klein 10 7977MPTT
When placing DCS2 files into a picture box the preview displays as a pixalated lo-res image. Tiff files are fine. The preferences are set to full resolution previews. Is there a way to make DCS2 files...
Looks like you would be better off just converting to tif files. Quark apparently has a problem with these type of files. You can try saving as Multi Channel. Make sure you set the preferences to Full Resolution Preview.
Nov 27, 2009 | QuarkXPress 7 Full Single User Mac/Win...
Need extenderfor Anne Klein watch model 10/8031 SVGY.
I would recommend going to a watch repair shop for this. Depending on the style of bracelet there are a couple solutions. I would suggest a shop familiar with or that carries Anne Klein.
Most repair shops will have extender links and clasps. If you have a fashion watch that doesn't have a typical clasp or bracelet set up a Anne Klein dealer will be able to better assist you in getting a solution from Anne Klein.
Precision Time has Anne Klein and they do a fair job of getting parts through their repair center. You can visit their web site at PrecisionTimeCo.Com.
Sep 22, 2009 | Watches
Error 1406
Here is the resolution :
Click on Ignore till the installation proceed. thats should work
If that does not work you can follow th steps given in folowing link
http://support.microsoft.com/kb/838687
Apr 10, 2009 | Microsoft Office Professional 2007 Full...
Need extra link for an Anne Klein 10-7977MPTT watch
Yes you can, go to amazon and take a look: Amazon com Anne Klein10 7977MPTT watch link. Wish you best of luck.
Cheers
Jan 01, 2009 | Anne Klein 10 7977MPTT
HP OfficeJet 4315 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
