Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer makes loud noise, like bad bearing while washing, and particularly when spining
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. If it is making the noise slightly when washing and real bad when spining like the drum hitting the outside of the washing machine the problem is the balancing springs are broke or streched out or the shock absorber type balancing mechanism has broken . Most likely not a bad bearing but something to do with the balance of the wash load.
Posted on Apr 23, 2010
FLC271W2 washer squeal during wash cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
May 23, 2014 | Frigidaire Washing Machines
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
Drive Motor
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
My washer started by spining faster then normal and then it started makeing a loud knocking noise and now sounds like metal rubbing metal. Everything else works fine just can't spin anything.
SOUND LIKE INNER TUB AND BEARING AND SUPPORT SHAFT...# W10250573 $364.00 INNER TUB AND SHAFT..REAR TUB AND SEAL#8181912 $224.00 VERY TIMELY AND EXPENSIVE REPAIR CHECK WARRANTY ON WASHER
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I n the spine cycle the washer makes a loud noise and shakes.I found a dime under the tube between the rim and door gasket.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 22, 2010 | LG WM2016C
WHEN SPINING MAKING A LOAD NOISE
your drum bearings have gotten water in them from the lip-seal on the drum drive shaft,you need to remove the rear access panel,remove the belt remove the pulley,then remove inner tub and remove the spider that holds the inner drum on,then remove old seal and replace the inner and outer bearings,dont do just the inner bearing as the outer one isn't that expensive and may go out later,and its very labor intensive,anywhere from 2 to 7 hours depending on how stuck the old bearings are in the machine
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
