Code F 33 on whirlpool duet waher. Sevice guy said I need a new control board, the bill will be $468.00. Some how I feel I am being ripped off. Thanks Paula
Thanks for responding. In wash mode it does not stop filling then it automaticaly turns off and drains.Thanks for responding. In wash mode it does not stop filling then it automaticaly turns off and drains.
You can't post conmments that contain an email address.
then i would say either water valve is bad or pressure switch or pressure hose plugged or hose is leakingthen i would say either water valve is bad or pressure switch or pressure hose plugged or hose is leaking
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU) • Check the Drive system for any worn or failed components • Check MCU • Check CCU • Check Motor • Check Wire Harness
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI http://www.appliancepartspros.com you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
F33
error code indicates a pump drive system error. If the pump ohms out
correctly and the harness is secure and working fine, I recommend replacing the CCU
(central control unit).
Hi, F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board which needs to be replaced.
Hi, The F33 code is a pump failure code. The control
unit is not measuring the proper amp draw on the pump during pump out.
Remove lower panel and unplug then replug in the pump 2 or 3 times to
remove any corrosion. While your down there, take the front of the pump
off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE
SERVICING!
Hello there If after 30 seconds the control does not detect water entering machine,
the valves will be turned off and the error code will be displayed. OR
If the control has turned the water valves on, and after 8 minutes, the
flow sensor has detected 10.5 gallons of water passing through it, but has
not detected the pressure switch trip, the valves will be turned off, and
the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
the fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
