Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
I have this xternal drive and its resently started goin solid red
I have this xternal drive and its resently started doin this the light turns solid red ones it starts transfering files it was fine but now it wont let me transfer im able to us it but not transfer in to it .. why does any one have a anwer to it thanks u ..
I would try using the software called spinrite 6
http://www.grc.com/sr/spinrite.htm
Posted on Apr 23, 2010
I have a BMW 320i 1995 v6 automatic transmission when I start the it's normal bt when I put it in drive n drive while shifting it takes time doesent shift normaly the rpm rises bt the car is nt goin is...
Are you getting a transmission warning light in the dash? If you get a warning light, you should have someone check the thermistor that reports the transmission temperature to the ECU. If you are not getting a warning light, it is probably time for a transmission rebuild.
A '95 probably has over 200,000 miles on it by now, right? If it has ever been treated roughly, and/or if the fluid has not been replaced every 50k miles or so, the transmission is due for some work.
Mar 13, 2011 | 1995 BMW 3 Series
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Installed a new ingintion switch know security light flashes and car will not start
this process will take about half an hour to doyou might want to put a battery charger on it on the low setting because if the battery dies in process u have to start over.first thing is try to start car,it might start then stall,when that happens leave the key in the on position and the security light will be flashing and it will keep doin it for 10 minutes,then it will stay on solid,when it does that turn the key off for 2 seconds then turn it to the on position anfd the light will be flashing agian for 10 minutes,then it will be on solid,then turn the key off for 2 seconds and then back on and 10 minutes later when it stops flashing this time u should be able to start it and the light should be off,hope this helps
Sep 23, 2009 | 2003 Oldsmobile Alero
Solid red light, flashes green when i turn it on then it dies.
Pretty much the only thing worth trying is starting the PS3 without the hard drive.
If it doesn't work it's more than likely a GPU problem that only Sony can fix.
Either way check out my guide here for tips and details.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 28, 2009 | Sony Playstation 3 (PS3) Console
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
184 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
