Question about Watches
My wcsr4170giww will not spin. it is two years old and used very little. What should I look for
  • 299 Answers
Sounds like it needs a new battery. A watch shop can change it and the gasket for about $8.
Posted on Apr 24, 2010
Self whinder starts then stops after a couple of seconds ???
If you have had it for a good while, it probably needs a cleaning. And a little lube to keep it ticking.
Apr 30, 2014 | Rotary Watches
Tip
Best Saltwater Spinning Reel for 2016-2017
Now that you know a little bit more about what you're looking for in a saltwater spinning reel, you probably want to know what some of your better options are. So here is a list of ten of the best saltwater spinning reels currently available.
Saltwater Spinning Reel Archives Top Spinning ReelS
on Nov 24, 2016 | Omega Speedmaster Day Date 3520.50.00...
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
The day inscription is two days late, monday, watch says saturday
So to change the Day and Date of your Watch, slowly pull the Stem out... (Do note that if you have a Waterproof Watch, you'll need to unscrew the Stem counter-clockwise, which is towards you, until it unlocks, then you can pull the Stem out!) But this is where you need to go slow. If you pull it out slowly you should hear one snap. (It stops on the first notch) If you pull the Stem out all the way, it snaps twice and ends up on the second notch. (See picture below) The second notch, or all the way out, is where the Stem needs to be to set the Time.
day-changed.gif But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date!
Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch!
If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle.
Jun 27, 2011 | Watches
How to clean a watch with water crossion its old and its an windup watch.
i personally have a older watch my father gave me years ago, belive me or not, i use tuthpaste and old soft toothbrush. spread paste on watch lightly, let set for a few moments, then with very little water,use brush vigerusly all over,on face, stem, back, band,and buckle if it has one. when clean to your liking,dry with clean towel and enjoy
May 30, 2011 | Watches
M/D Collection Gents Mechanical Automatic Watch 22-800 running slow. Around 3/4 years old
It sounds like it could do with a clean. Most makers recommend cleaning every 2-3 years, so perhaps yours is a little overdue.
Feb 16, 2011 | Marcel Drucker Watches
I had not used my lucien piccard watch for years how can I get it to work now I was told it works with your body however mine is not moving
might need to be wond, pull the crown out and with each click spin it, if its winding the hands wont move and just feel a little resistance and u can hear it if u hold it to ur ear, do it about 20 rotations.
please rate this answer,
Nov 25, 2009 | Watches
How do you get a GapKids watch out of military time?
press the mode button 3 times and it will be on time setting press restart until the hours are blinking then hold the start button til it says am or pm
Aug 02, 2009 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
Light
My watch had the same problem and i could never figure out what it was so i just lived with it for a couple of years. then, just recently even when my watch was getting plenty of sun the battery would die in the evening and shut off at night. so i replaced the battery and evrything works great. even the light which leads me to believe the solar panel is just a gimmick. i have an old g-shock watch that i bought in 1989 and it still works and is on the origional battery. my gw 300 is about 5 years old and needed a battery. i guess 5 years on a battery is prety good but i would rather have it last for 19 years like my old one.
Jan 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
43 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
