Question about Lands Phones
My at&t phone system is intermittently having line noise, like a crackle when using intercom or outside line. I have checked the lines and the replaced the connectors. any ideas?
    President:
  • 860 Answers
I,m guessing that the card your having a problem with is a 206E card. They would get intermitent static on all lines and intercom/page that would come and go.
typically it occours on the first 2 ports of the card but can also migrate to others. Unfortunatly, the problem resides in the card itsself and the only remedy is to replace the card or move the staticy phone port to a new one.
Posted on Apr 23, 2010
When I try to dial out the phone has loud crackling noise.
You have a line problem call your Telcom provider.
Feb 06, 2016 | Lands Phones
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    We are a small company and we use the rca 4-line Intercom Speakerphones. Out of 4 phones one has the intercom button that continously flashing blue and red and the intercom does not work. The other 3...
    The phone may have the same extension as another phone in the system. Unplug it from the power and take out the battery for a minute. Then plug it back in. It should take a moment to find other phones on the system and assign itself an extension number.
    You may also have a line reversed on that phone. Check to see if line 1 is line 1 on all of the phones. Then line 2, 3 & 4.
    Another thing to check is the DSL filter. That phone may need a filter on the line to keep your DSL from interferring. If it has one replace it.
    May 21, 2010 | RCA 25423RE1 Phone
    Our fax machine is receiving faxes but won't send them. It says poor line condition. I've switched the actual line with another & it still says the same thing.
    Sounds like you hve "noise" on the phone line you are using. Try plugging a normal phone into the line socket you are using for faxing, then pick up the reciever to make a call. If you hear crackling then the line is noisy and you need your phone service provider to repair the line. If you dont hear crackling try using another line lead.
    Mar 04, 2010 | Brother Multi-Function Center MFC-240C...
    Divice goes to intercom not a outside line
    just dial 9.
    If this is more of an issue of auto line select, we need to know the model of the phone system. Merlin 820? 410? 1030? 3070?
    Sep 29, 2009 | Avaya AT&T Merlin Basic Telephone & Modem...
    Meridian M7310 intercom key not working on anyphone
    Do Feature **CONFIG, go to CONFIGURATION, select the second option, should say Line something, keep scrolling and it will say I/C: #,. press change, you can have a max of 2 Intercom keys, if you need other info, go to youtube.com and search for "thenortelguy"
    Aug 28, 2009 | NorStar Meridian M7310 Phone
    1 lines is ringing & another is not ringing
    Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
    This is assuming that the lines are already programmed to ring at the phone.
    Carl
    Aug 21, 2009 | Panasonic KX-T7730 Corded Phone
    Lands Phones Logo
    117 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
