Question about Vacuums
Hoover Windtunnel not picking up as well
Hoover windtunnel doesnt seem as low to the ground, is there an adjustment or the brushes worn out? I also just chaged the belts but didnt change the brushes.
  • missguided1 Jun 04, 2008
    My entire house is either bare floors or high grade commercial grade office carpet. Even on the lowest setting, the brushes don't "deep clean" and there is barely any drag on the brushes on the forward or backward stroke. I've tried a new belt and am considering a new roller, but the original has less than 10 hours on it. I have measures the bristles and all seems good, but it acts like the height adjustment simply won't allow the head to go low enough. As long as I have good suction, it does s good job on area rugs because the suction pulls the rug up against the head. Otherwise I'm just using a glorified vacuum cleaner that only picks up surface dirt. Any suggestions?
  • Anonymous Mar 27, 2014
    I have a new belt and need to change it. I have the cover over the brush off, but don't see how to get at the other end of the belt.
  • 126 Answers
There is a height adjustment on these vacuums and they are set to adjust in the "handle up" position". It will appear that the adjustment is doing nothing when the handle is up, but the setting will take affect when the handle is lowered.
You can check the brush length with a pen or pencil. Turn the machine over so that the brush is visible and run the pen or pencil flat across the bottom plate. Any where the brush is extending outward, your pencil should contact the bristle. If not, then the agitator should be replaced.
Also, check to make sure that the agitator is rotating freely and that the filters and bag are allowing for adequate suction. The machine will only pick up if the air flow is sufficient.
Posted on Mar 23, 2008
My hoover windtunnel is not picking anything up all of a sudden. Also the roller underneith is not spinning. I've replaced filters and the attachment part is working fine, just when it's in the upright...
The belt that drives the brush roll has broken. That's why it doesn't pick up and why it doesn't pull itself forwards. Check the User Manual (download from Hoover website if necessary) for information on replacing the belt. Good luck!
Feb 05, 2010 | Hoover U6630-900 WindTunnel Bagless...
The windtunnel vacuum has suction but does not pick up the dirt. I'm puzzled as to what might be the problem. Help!
The problem is that the belts are stretched and worn and slip instead of turn the brush when it is put against the resistance of the carpet. You simply need to replace the belts. Here are the (2) belts you need and the manual with instructions:
Hoover self-propelled windtunnel belts
Manual
Jan 02, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
It seems when i am vacuuming it is very hard it move and the brushes does not rotate after the rug strings got into it.
Your belt is stretched or worn and therefore cannot turn against the resistance of the carpet. If you replace the belt it will fix the problem. You can get the belt you need here:
http://www.vacbelts.com/hoover-windtunnel-belt-.htm
Oct 24, 2009 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Windtunnel U 6439-900. The agitator brush will not turn. I installed 2 new belts, # 38528034, and # 38528-035 There is so much slack in belt # 3852034 (brush drive) that it cannot grip the...
There is an idler pulley that takes up the slack in the V belt when you pull the handle back to vacuum. Make sure it is engaging properly and the V belt is installed correctly.
Sep 09, 2017 | Hoover U6630-900 WindTunnel Bagless...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Windtunnel U6425-900
have you tried raising the 'carpet level' adjustment?
Oct 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
596 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
