Question about Acer Extensa 5620 Notebook PC
Acer 5620 Black Screen, but can just about see an image there. I have tested my laptop screen on another laptop and is working fine. Laptop works fine on external monitor. Looks like it is a motherboard problem. Has any one a fix for this please.
  • sales345 Apr 23, 2010
    I have test my screen, which as the inverter in the screen assembly.
    The whole screen assembly was removed from the laptop and test on another laptop and it worked.
    The inverter and screen are good.
    Yes, that is correct.
I am facing the same problem. A guy old me that there is an IC on MB that is responsible to power the inverter board...but he asked for 50 pounds for its repair. I am searching for that IC and till that, I am using an external monitor.
Posted on Apr 25, 2013
    President:
  • 1,149 Answers
Hi:
If you have tested your screen, then the problem is most likely the LCD inverter assembly. It is usually mounted near the bottom of the LCD, is a tiny circuit board, approx 1/2" wide by 4" long. it is what powers up the backlight on the LCD, and they don;'t cost too much, maybe $15...Hope this fixes it!
Posted on Apr 23, 2010
  • Larry Chandler Apr 23, 2010
    If I understand you correctly, you moved the entire screen assembly to test it? LCD, inverter board and cables?
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer 5620 will boot up then resets to initial
Well it seems that the operating system of your laptop is crouped due to some region like may be have virus in the laptop or due to not proper shutdown etc.....
you need to recover or reinstall the operating system using the boot-able CD of that operating system.
please let us know what operating system you are using, so we can help you in details.
Good Luck!!
Thanks
Dec 22, 2009 | Acer Extensa 5620 Notebook PC
Acer Aspire screen in Extensa
Hi, yes they should change over no problems as long as power and inverter are same or replaced, follow these diagrams or check for more details,
http://www.laptoprepair101.com/laptop/2006/07/08/notebook-display-diagram/
Best of Luck,
Terry
Dec 21, 2009 | Acer Extensa 5620 Notebook PC
Acer Aspire 5672 WLmi: Near - Black Screen
check your inverter try to use to other inverter...
Sep 10, 2009 | Acer Aspire 5672WLMi Notebook
Monitor/tv output with a pink haze - Help
Try to reconfigure the settings of your laptop then load its default setting to display its normal view.
Thanks
Aug 06, 2009 | Acer Extensa 5620-4677 Notebook
Acer 5620-6266 notebook will not boot--Media Test failure
Open BIOS and configure your boot devices priority. First boot device should be the hdd. Also check if the laptops see the hard disk, i think your hard disk have a problem and thats why laptop wants to boot from network.
Jul 18, 2009 | Acer Extensa 5620 Notebook PC
Intermittent video problem on acer extenza 5620.sometimes video display backlight will work sometimes it fails.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 09, 2009 | Acer Aspire 5670 Notebook
Acer Extensa 5620 Notebook PC Logo
497 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
