Question about Video Cameras
Sony CCD-FX620 Video8 LP/SP selection problem
The problem is in playback the camera switches to LP mode even when a tape recorded in SP mode is attempted to be played back. I would appreciate if you could provide some insight into this problem.
Thanks!
I have the exact same problem. I have only used the same camcorder to record and it will not record in LP mode on SP, so I have no idea why or what senses that the tape was recorded in LP mode. I have tried 2 different recorded tapes and 1 brand new tape. Same result for all 3. I have run the head cleaning tape twice with no change in the results.
  • froggy17 Mar 23, 2008
    When i go to hit the play button it wont play it fast forwards any sugestions?
  • cemmer62 Sep 09, 2008
    I have the same problem: when I record in LP (90 min) mode on mini-DVs
    the camcorder will only play back in SP (60 min) mode. Everyone
    appears to be running in fast forward. I use a JVC GR-DVL120U
    camcorder. Old tapes recorded in LP mode work fine. I've
    checked all the set up parameters. I did add a longer life
    battery recently.
4 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Switched back and forth between SP and LP in playback
The control track on the tape is not being sensed properly, or there may be a fault in the capston circuit, or capston drive.
There are a number of issues that can cause this:
This can be a dirt film on the control track head, or the main video drum heads, or warn head surfaces. It may also be an alignment problem due to warn parts. The electronics that read and process the control track, or video synchronization processing may have a fault.
The first thing you can do as a user is to clean the tape path. It is safest and usualy works well to use a cleaning tape for your camera type. Follow the instructions for the cleaning tape. The cleaning tape has a surface on it that is supposed to clean the head surfaces without causing a disturbance. Usualy the time required is about 5 to 10 seconds, depending on the model of the camera and the type of tape format.
Read the instructions that comes with the cleaning tape. It is not recomended to re-wind and re-use this tape.
Past this point, the camera will have to be serviced.
Jerry G.
Posted on May 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Posted on Nov 24, 2008
Davidivory1
  • 338 Answers
SOURCE: i have a sony 8mm camcorder model ccd-fx620. I
Put your camera on charge with it's charger you got with it, charge it for at least 2 hrs and the power will be enough to get tape out.
Posted on Jun 16, 2010
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Changing my record mode from SP to LP
In order to change the menu settings you must 1.)turn on the power 2.) Touch FN to display PAGE 1. 3.) Touch MENU to display menu. Use the arrow buttons to scroll until the TAPE SET menu is highlighted. Press the exec button to reveal SP in RECORD MODE. Press it again to bring up a menu that will give you the choice of SP or LP. When you're done press the exec. button a couple of times and you're done. Do Keep that even though the tape will run 1.5 its normal length there are certain features that cannot be used while in Long Play (LP) mode. I have a sony camera but was looking at your model camera yesterday. I noticed that many of the menus and navigations were the same. I'm assuming that my directions will at least allow you to know what menu to look for. Good Luck.
P.B.
Oct 15, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
LP/SP mode
Seems your Canon doesn't support LP mode playback. Please see its user manual and check its specifications for LP mode playback.
Aug 17, 2008 | Canon ES8400V Camcorder
Can I change the recording speed?
Hello tiffany27,
Go to menu of camera and find Record Mode, there you can select SP or LP. SP stands for standerd play & LP for long play.
May 28, 2008 | Sony Handycam DCR-VX1000 Mini DV Digital...
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Setting the tape speed
Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
You can not change speed SP/LP during playback mode because its properties of signal set during recording.
Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Video Cameras Logo
339 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
