Question about HP ScanJet 3670 Flatbed Scanner
A pink line is appearing on scanned documents?
  • 16 Answers
If it's a vertical line from top to bottom (portrait), then one of the sensors in your scanner bar is burned out. Unfortunately, there's no fix for this, as that is a hardware problem and not a user serviceable part. If it's under warranty, exchange it for another one at the place where you bought it.
Posted on Apr 23, 2010
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
How do i get rid of a black line that ahows up down the r side of scanned documents, there is no line on the originals
If you are using the Automatic Document Feeder (ADF) to scan, you may need to clean the scanner bar glass.
First test: See if the line appears when you scan on the flatbed. If so, it is probably a hardware failure.
If it appears only when using the ADF, you need to clean the ADF.
HP has a general diagnostic and cleaning procedure here:
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846928&lc=en&dlc=en&cc=us&destPage=document&product=391182&lang=ru
Apr 13, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Verticle lines appear on document when scanning through document feeder. No verticle lines on document when it is scanned face down on the glass. How do I clean the document feeder?
There is a thin strip of glass next to the main platen glass, where documents fed through the feeder are scanned. You most likely have Wite-Out or some sort of debris stuck to the glass. You can probably wipe this residue off, but if you need to clean that strip of glass, use alcohol and a lint-free rag.
Oct 07, 2010 | Brother MFC-7420 Laser Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Feb 13, 2007 | Visioneer Strobe XP 200 Path-Through...
HP ScanJet 3670 Flatbed Scanner Logo
657 people viewed this question
Seeker5211
Seeker5211
