Question about Toshiba Satellite X205-SLI1 Notebook
Black screen with info that pops up immediately upon booting up
As soon as my computer boots up I get the following that continues to rewrite itself. This started when I was copying document folders to a thumbdrive to move the info to another computer. A blue screen originally come up but the black screen come up with the info within a minute of the blue screen. ANY info? The info on the black screen that repeats itself; First line reads "For Realtec RTL8111B/8168B Gigabit Ethernet Controller v2.02 (060301)" Second line reads "PXE-E61 : Media Test Failure, check cable" Third line reads "PXE-M0F : Exiting PXE ROM".
    President:
  • 1,149 Answers
Hi:
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Posted on Apr 23, 2010
Black screen with cursor
Windows is corrupted or the hard drive has issues. If you have a backup cd recovery disc try it now, if that fails have the hardware tested for possible replacement.
Jul 27, 2012 | Toshiba Satellite L500 Series Notebook
Unmountable boot volume
Please boot from bootable disc and repair the OS.
Mar 19, 2012 | Dell Computers & Internet
When i turn my computer on it loads but then a erro message comes up so i want to do a pc reset and i have looked online useing my laptop and it tells me when i see a blue dell splash bar come up to press...
The procedure is actually correct. but if your computer is fast you may miss it. try this, upon turning the computer on, start pressing the CTRL+F11 immediately. if you have reformated your HDD then most likely you've lost the recovery partition for the PC Restoration.
godspeed
Jun 23, 2011 | Dell Inspiron 531s Desktop Computer
I have installed a SATA SH-S223C on a computer with Windows XP. But now when I try to boot the computer, it freezes on the Windows boot screen until I open the CD tray. Then it will continue on to the...
Do you have any CD in the tray, first would be to remove the disc if present as boot from CD would be first option in BIOS.
Get into the BIOS by pressing the appropriate key some systems it is the DEL key or F2. In bios select Advanced Bios Features.
Select Advanced Bios Features
Hard Disk boot priority,
Select "Bootable add in cards" with keyboard and keep pressing + until it is in the first location.
Set first boot device as Hard Disk and then save and exit BIOS.
F10 is shortcut to do this.
If you need to boot from CD next time just change first boot device to CDROM.
Jan 25, 2011 | Samsung SHS223C 22x Internal DVD±RW...
When I turn it on, I get a black screen which says: Windows could not start because of the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repail this file...
Get your windows restore cd (it's probably in your box) and boot to it. You may need to enter the boot selection menu and select "Boot from CD-ROM drive". It should then prompt you to press any key to boot from the cd, which you should do. Just follow the prompts, wait for the disc to load, and then press "r" for recovery when you are prompted.
The system folder does not delete itself, so run a virus scan as soon as you restore your computer.
Dec 31, 2010 | Acer Aspire One D255-2670
Hi there, have a strange problem with a brand new DVD SAMSUNG SH-S223C. Installed a few days ago and running latest SB05 firmware (Even I reinstalled twice this firmware). Now on boot with my WIN XP PRO...
Start up BIOS and perhaps change default boot drive to your hard drive because i think your default boot up device is the dvd drive.... try to put that last on the list... F2 should get you to BIOS if not try F8 Just keep tapping right at beginning of startup before the logo screen shows. Once in BIOS go to boot menu and change default device :) Hope that works for you
May 04, 2017 | Samsung SHS223C 22x Internal DVD±RW...
Eeepc 1001HA won't boot.
Take the battery out, leave it unplugged for a day or so... usually resets the bios for me. Sometimes though, you might have to manually unplug the cmos battery as well, that involves opening the system.
Apr 14, 2010 | ASUS Eee PC 1000HE Netbook
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Toshiba Satellite X205-SLI1 Notebook Logo
216 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
