Question about Canon Pixma iP2600 Photo InkJet Printer
My canon ip2600 printer has a paper jam error, but there isn't.
My canon ip2600 printer has a paper jam error, but there is no paper jam. What do I do?
  • 4,345 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE:
Paper jams on one side
If you wish to get some details about printers an copiers error codes and repair ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
May 21, 2016 | Canon Pixma iP2600 Photo InkJet Printer
Error paper jam?
clear paper inside, there must be a piece of paper jammed inside
Jan 24, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My Canon ip2600 keeps getting jammed. It takes
Lol!!! I was having the same exact problem--- looked in it, didn't see a thing, opened it, still didn't see a thing! I turned it over-- and sure enough, a pen fell out!! lol
Jul 21, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Canon pixma ip2600 load paper error when there is paper
Do you have the manual? If so, go to Cleaning the Printer and read Cleaning the Roller, make sure there are no foreign objects in the rear tray and try turning the printer Off then back On OR even a can of that compressed air to try blowing the inside of it out. If you don't have the manual you might find it online. I tried copying the Cleaning part but it wouldn't let me.
Apr 06, 2010 | Canon Pixma iP2600 Photo InkJet Printer
I have a canon IP2600 printer only 4 months old and not used too much. It just started to pull the paper to one side when I try to print then it says there is a paper jam. The paper has an indent/groove...
In many cases, forcing (pulling out) the jammed paper in the printer might caused severe damages on the gears or some parts on the mechanical stability.
Noise problem might occurred if some of the joints (parts) were dis-aligned. Dis-assemble carefully the printer, and look for that damage. Put some grease and assemble.
Jan 20, 2010 | Canon Pixma iP2600 Photo InkJet Printer
My canon ip 2600 keeps popping up paper is jammed
hmmm...
I think the paper pick mechanism has failed..
try to add some paper to it..so the paper pick can easily pick it...
if the problem still exist ..try to full out all the paper in the tray and put it again..
May 12, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Printer not working.
i get a paper jam light but no paper is jam my printer is new whats up!!!
Nov 27, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
2,592 people viewed this question
Clive
Clive
old marine
old marine
Ekse
