Question about Nokia 6233 Cellular Phone
6233 crashes/white screen/resets .. when scaling down image..
Whilst takin a Pic on my 6233 i go to send it via multimedia it crashes then goes to a white screen it then returns to my standby screen ..(without asking me for my pin numbers)
This is my 2nd phone..
I recently returned it to nokia care center in victoria Australia, also including one of the speakers is not working. i got it back a week later they didn't fix speaker fault & the picture scaling fault was fixed til i took a pic the next day and tried to send it, Now is rat-**** again.
* I have tried setting the image quality to LOW
* and reducing the image size to 640x 480.
* i have a 1 gig mem card in it..
BTW..dont buy this phone if u plan on using video call as you have to stand infront of mirror to see who you are talkin to..
C'MON nokia get with the program.
my next mobile/cell is phone is a sony for sure..
hollywood64
    Sergeant:
    Champion:
  • 283 Answers
Sorry for you... if i could only get my hands on your fone,, i'm going to fix that..they could replace your speakers, and they can repair your flash ic, ram, or cpu,. probably what they did is flashing the same firmware on u'r fone.,, and they did'nt maybe observe the things goin on to u'r fone.. so they've just did'nt.. but they can fix it too bring it back to them.... well if they did replace your speaker and check the lines that is ok.. so your main problem of all the things happening to your phone is the main parts... is the ( uem ) power and audio ic.. if you cant hear.or you can hear but its bubbly, anything transmit voice faulty.. this is the faulty one..
Posted on Apr 21, 2008
SOURCE:
White screen problem nokia 6300
Hi, It is the software that has crashed and requires a full software reimage. You will need to take to a repairers who can connect to computer and reload fresh image.if you want it repaired the cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it whilst you wait or the next day at the latest. GoodLuck=)
Aug 02, 2011 | Nokia 6300 Cellular Phone
My Nokia 6233 Hangs & Then Shuts Down.
check the side button PTT
and make full reset
May 11, 2010 | Nokia 6233 Cellular Phone
White spots in corners
"It's referred to as 'flashlighting'. It's a common problem in LCD/led as the driving factor is lighting pushed through pixels to create the picture. What you are seeing is a spot where the lighting is passing through unscathed or overpowering around the edges since this is an edge lit tv.
Some TVs are worse than others even if they are the same model, size and even batch.
This can be caused by many reasons... You have 2 options, return and/or exchange it at your local store if still in that window. Or you can call the tv manufacturer to see if it is out of their allowable tolerance levels.
Remember some flashlighting is still within their specs so even though you may not be happy with it the manufacturer may not fix it.
Many people find some relief by turning brightness down, contrast down and some TVs allow you to adjust back light levels. If this one does then make sure it is not on high.
For more info on this I would go to hidefjunkies.com as it has tons of great info."...Also,"take it off Dynamic mode is the first step. Then put it on something like Standard or Movie. This will not fix it permanently, but will give you a better experience." (I hope this answers your question...if it was ME,I would take th darn thing back,if still within warranty period.)
May 09, 2017 | Vizio L37 Television
Our picture is yellow
first check the cable. second, go into the menu and reset the settings to factory default. this will reset any image changes and the resolutions. third, clean it out. dust collecting on the colorwheel will cause this, too. if you still have a problem and you just bought it, it should still be under warranty, so send it in to get repaired for free.
Sep 02, 2009 | BenQ MP610 Multimedia Projector
How do i set up my pic message
when ur on a pic go 2 send via or send wateva it says it might say sumin like multimedia message?
Jun 25, 2009 | Sony Ericsson Walkman® W880i Cellular...
Crashing with white screen
HI, you will need to send this phone in for a board transplant. the internal programming is corrupt. the reason for the crash is because the core software cannot Initialize itself to run the OS or, core software.
May 22, 2009 | Nokia 6233 Cellular Phone
Upside Down Image
Hi there
Go into the Menu - you'll see a subfolder that either reads : Flip image or Mirror.
Go into this subfolder and change the image. If it doesn't work or you still can't find it notify me and I'll draw the user's manual and mail post you the exact steps.
Apr 01, 2008 | Hitachi ED-X3450 ED-X3450 PROJECTOR...
Large white vertical bar thru picture during projection
Two reset attempts to factory settings seems to have been the fix.
Feb 01, 2008 | Toshiba TDP-S8 Multimedia Projector
Nokia 6288 will not send multimedia txt
If you are sending it via bluetooth,
ensure you have enough free phone memory.
If you are sending the stuff via MMS,
Ensure that the image is of appropriate memory size.
Also, tell me, by what method/way are you sending the image, so that I can help you better.
Please rate.
Dec 15, 2007 | Nokia 6288 Cellular Phone
Nokia 6233 Cellular Phone Logo
460 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
