Question about Whirlpool Duet GHW9150P Front Load Washer
Wahser not fully draining
I have a Whirlpool GHW9150PW0 that is not fully draining the water out as clothes are still soaking wet when finished. Is this a common problem and can I fix it at home with a little knowledge. Thanks in advance for any help.
    President:
  • Whirlpool Master
  • 2,651 Answers
Sure, might be as somple as your using hte wrong soap. you MUST use an HE detergent. regular detergent creates too much suds for these smachines and result in the control panel displaying "sud", or innadequate drain issues. if you are using hte correct soap then next thing to check would be the pump hosing for debris blocking pump assy.
1. remove the lower acess panel with (3) torx 20 screws
2. the pump is located right in front you see ascrew type handle on fron of housing
3. unscrew the handle and clean debris from housing nad return the cover. check for spin now
4. if water remains in the tub after drain/spin, ther will be water in hte machine, so try tipping machine back, using hose pinch off pliers, or what i do is open a white trash bag in front of pump assy, so when i open the bag catched it all
Posted on Mar 23, 2008
SOURCE:
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
WHAT DOES HF OR FH MEAN ON A DUET WASHER MODEL GHW9150PW0
this error indicates water is not being detected coming into the machine. many things can cause this issue but start here
be sure that water valves are turned on. besure the filters inside the machine water valve(where hose hook to machine) are not clogged. also make sure drain hose is not installed into a drain pipe tightly. it should just rest inside a pipe or on the edge of a utility sink. when installed tightly into a pipe it creates a suction and syphons the water out of you machine and then your machine will never reach a "full" water level
WWW.LARTODAY.COM
Dec 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
After the clothes spin out the bottom ones are still soaking wet
Remove the pump and check for obstruction. This video will help you to access the pump.
May 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool washer drains to rinse but when it spins it spins very slow clothes stay soaked
Your machine is not comeing out of the nutrual drain the motor can't tur the tub full of water and wet clothes or it will sling water out and will burn out the motor very quickly so the transmission has a nutrual drain you will need a new transmission sorry
Mar 31, 2009 | Washing Machines
I have run the machine on a daily wash
It sounds like your water discharge pump is either clogged or not working to full capacity. You can check this by looking at or feeling your discharge hose during drain and spin to see if the water is actually draing fast or just dribblig. If this is the problem then call a teck or change the pump yourself. If you do it yourself please unplug your unit before working on it. I hope this helps you.
Nov 20, 2008 | Indesit W 123 Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
169 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
