Question about Roland Vs2400CD Digital Workstation W/CD Recorder System
My Roland xc540 is making a noise like the bearings in the cutter are faulty. I have changed the bearings swooped the cables round and still makes the same noise. Occasionally it does not do it. starts slowly and gets worse and worse until it gives me a scan moor error 10010.
When I turn my weed eater on it makes a loud noise what could the problem be?
will assume electric
fixable
would say bearing at the cutter head dry or worn out
when you turn the head to edger the load on that bearing is different
if noise is up in the motor same thing .. bearings
Oct 13, 2016 | Garden
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
I have a Royal Orca 9512x paper shredder. When I use it , it makes a very loud ,metallic squeeking sound. How can I correct this? It shreds fine. It's just noisey.
To fix this get some dry Graphite spray lube....
Spray graphite
Spray this on the cutters and sides of the cutters to lube the cutters and bearings....this will stop the noise...and prolong the life of the machine...
heatman101
Jun 18, 2011 | Royal 15MX Shredder
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Roland vista problem
maybe you did not install it properly.try this turn off your cutter. plug the cable to you pc. make sure your pc is on. then turn on your cutter. then windows vista will detect new hardware then continue installation make sure you point to the correct folder. then you will see in the taskbar that says installed new hardware and ready in use. please install also the software bundled with the cutter. or if it support corel draw you can start designing and make sure that you put an outline on the object. example letter "t" put an outline on letter "t" and try plotting it. maybe this will help.
Aug 03, 2008 | Computers & Internet
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Roland Vs2400CD Digital Workstation W/CD Recorder System Logo
103 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
