Question about Singer 7442 Mechanical Sewing Machine
Brother XR37 I just got this machine from a friend , she never used it, but I cant get it to pick up the bobbin thread . Ive checked to make sure the neddle in is right and the bobbin is in correctly . Is there something else I can check? I've been around sewing machines all my life and have about 6 different ones I've worked on before but I havent seen any act like this one . Can someone please help ?
  • Anonymous Apr 13, 2008
    I have a Janome Newhome model 108.
    it will not pick up the thread from the bobbin.
  • battyt Jan 26, 2010
    How to sew a buttonhole with the brother xr-37?
  • 136 Answers
Make sure the needle is fresh, remove the needle plate and take out the bobbin case. Turn the hand wheel slowly watching to see if the point of the hook, rotating circular metal piece that the bobbin case sits on is the hook, comes by the needle before or after the eye of the needle has raised above point of the hook. If the needle eye is above the point of the hook when point passes needle machine is out of time and should be taken to trained tech. FYI the way to fix this problem is not to lower the needle, generally it is a repositioning of the hook rotation best left to trained tech
Posted on Jun 19, 2009
  • sewtexas Aug 26, 2009
    sounds like out of time, if needle correctly inserted is a good condition. take for repair
    Problem Solver:
  • 6 Answers
HI, I HAD THIS PROBLEM ONCE AND HAD THE WRONG NEEDLE, ALSO IS THE NEEDLE EVEN SLIGHTLY BENT? DOES THE MACHINE HAVE THE CORRECT BOBBIN, MAYBE THE OTHER PERSON BOUGHT NEW BOBBINS AND THEY WERE THE WRONG ONES...I HAVE DONE THAT ALSO. I USUALLY USE COMMERCIAL MACHINES, BUT I HAVE FOUND THAT THE NEEDLE HAS TO BE REALLY STRAIGHT, AND NO DINGS IN THE PLATE. AS YOU KNOW FROM EXPERIENCE, IT DOES NOT TAKE MUCH FOR A MACHINE NOT TO WORK. I WOULD TRY NEW BOBBINS AND A NEW NEEDLE FIRST AND THEN LOOK AT THE TIMING. IT MAYBE JUST A SIMPLE THREADING PROBLEM ALSO. I SEW ALOT AND OVER THE YEARS HAVE THE MOST OBVIOUS PROBLEMS JUST PASS BY ME. HOPE THAT YOU CAN FIND OUT WHAT IS GOING ON AND ALSO, IS THE BOBBIN IN BACKWARDS, I HAVE DONE THAT TOO...
Posted on Jun 17, 2009
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
My brother innovis machine has a problem. Top thread frays and breaks, not not seem to be picking up bobbin thread properly. I have changed the needle tried a previous bobbin.
Be sure to install a brand new needle--check that the needle eye is the correct size for the thread you are using--a small needle eye will shred heavy thread. It may also help to remove the top thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Try different thread--AVOID old or bargain bin thread. Check that the upper tension is not too tight.
If the top does not pick up the bobbin thread, the machine may be out of time.
Otherwise, there may be a burr or snag somewhere along the thread path that is catching and fraying the thread. Sometimes there is a snag in the bobbin area (possibly the needle plate or hook) that is rubbing the thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
What Causes My Thread to Shred
Fraying Breaking Madeira
Nov 09, 2017 | Brother Sewing Machines
How do I reset the timing on my brother vx 1120 model?
Be sure to install a brand new needle.
If it still doesn't work, then search for "sewing machine timing."
Jul 28, 2017 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
My brother sewing machine special edition XL_5700 not picking bobbin thread
when installing a full bobbin make sure that there is at least 6" of thread outside the carrier slot
other than that check the needle /hook timing
Jun 18, 2016 | Brother Sewing Machines
My brother pe150 embroidery machine does not pick up bottom thread and wont sew
try changing the needle
rethread the machine--use every thread guide
make sure the bobbin is not warped
make sure the bobbin is inserted correctly in the case
it's very possible that the timing of the machine is off & the machine would need to be checked at a sewing machine shop
Mar 20, 2012 | Brother Sewing Machines
Brother sewing machine ls-30 will not draw up the bobbin thread what should i do
Check the needle to see if it's damaged
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
"the needle is not picking up the bobbib thread"
Check everything for burs. Something is stopping it from the bobbin. Also make sure you use can air and blow any debris from bobbin area.
Aug 31, 2009 | Brother CS-8150 Computerized Sewing...
Brother bobbin tread will not pick up
when i sew the thread keeps cutting help
Jul 29, 2008 | Brother XL-3500
Singer 7442 Mechanical Sewing Machine Logo
172 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
