Question about Inverter Pure Sine Wave 1500w Inverter
Im a installer of kitchen and bedroom cabinets some one at work said about a inverter instead of a generator for i havent got enough space in the van for a generator and i go onto sites without power ive got a dropsaw at 1430watts of power what can you recomend
  • 3,740 Answers
I and welcome to FixYa. I am Kelly. If you have a single load at 1430 watts and possibly some other item using power figure your max working load at 2000W. I would recommend a 3000W inverter.
The problem your going to have with an inveter that size is a single battery is probably going to die an early death trying to keep up with it. Your prbably going to need to parallel a 2nd battery into your work vehicle.
This inverter is what I would recommend so that no matter what you did to it (6000W burst load) you are not getting it fixed or replacing it.
http://www.invertersrus.com/vec051d.html
At $329.00 it isn't cheap but you spend the money ONCE vs repeatedly.
Kelly
Posted on Apr 24, 2010
Can I run my kenmore bottom mount refrigerator from a generator that is not an inverter generator
Yes. The generator must be large enough to produce the necessary amperage to run the refrigerator. It doesn't matter if it's a inverter generator or not.
Aug 04, 2014 | Kenmore Refrigerators
OH error in toshiba inverter VF S11
Follows are the part of the manual
Possible causes
• The cooling fan does not rotate.
• The ambient temperature is too high.
• The vent is blocked up.
• A heat generating device is installed close to the inverter.
• The thermistor in the unit is broken.
Remedies
Restart the operation by resetting the
inverter after it has cooled down enough.
• The fan requires replacement if it does
not rotate during operation.
• Secure sufficient space around the
inverter.
• Do not place any heat generating device
near the inverter..
May 03, 2014 | Toshiba Electronics - Others
I dont have much space in my bedroom and Im looking for a corner vanity
Strangely, when I searched for corner bedroom vanities, I couldn't find many which is weird. It makes a lot of sense putting it in the corner and using the space in a wise way. In any event, maybe you should have the vanity custom made for you. Many times it turns out to be cheaper then buying on-line or in the store. This way you will also be able to design it yourself.
May 29, 2012 | Furniture
I have 2 alba tv/dvd combi's.1 in kitchen & 1 in bedroom.After digi switchover 1 in kitchen is fine after re tuning.The bedroom tv only has a few stations after numerous re tunes.Both work off
The one that does not work: have you tried to unplug it for a while from power and plug it back to see if it will reboot and allow you to program?
Apr 08, 2012 | Televison & Video
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Apr 26, 2009 | Jacuzzi Kitchen Iron Black Finish...
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Can a dish washer be installed in a corner of my kitchen cabinets
It depends on you kitchen layout. If it is small and you need a place to install the dishwasher, the corner is fine. It is no different than placing a sink, wall oven, or refridgerator there. I have done all of the above, and they were not in small kitchens.
Dec 09, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Installation of kitchenaid range - KGSS907SSS
hi every stove that i have worked on and believe me that's a few and all gas or electric were all right up against the counter tops with no space at all so i would install the cabinets thanks please a positive feed back and accept please the appliance doc
Sep 23, 2008 | KitchenAid Kitchen Ranges
Inverter Pure Sine Wave 1500w Inverter Logo
70 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
